Good rule of thumb?
thzero
Good rule of thumb? - 03.15.2010, 03:21 PM
Ran across this elsewhere; by overgear I'm assuming that it means too high of gear ratio, undergear means too low of gear ratio. That sound right?
Hot motor, cool controller, cool batteries = undergeared
Cool motor, hot controller, hot batteries = overgeared
Warm motor, warm controller, warm batteries = happy components
Reason I ask is that I had overgeared my XXX-T slightly when switching to brushless and the motor was getting hot. So the solution was to lower the gear ratio by going to a smaller pinion. So this seems a bit backwards, or I have my under/over definition wrong.
SunnyHouTX
SunnyHouTX's Avatar
03.15.2010, 03:47 PM
Yeah, the definitions are a little mixed up there.
03.15.2010, 10:58 PM
As a rule of thumb those guidelines are correct, but there are always exceptions top the rule:-
way over geared - hot everything
motor too small/ underpowered = will run hot regardless of gearing
etc etc. What motor & kv & voltage were you using?...
thzero
03.16.2010, 11:05 AM
Mmms. Ok. Well, as far as the XXXT, its a 5700/MM running 30C 4000-4200MaH batteries 2S batteries (from variety of sources). I honestly don't remember what the original gear ratio was that I missed, but basically I scratched it went and figured out the overall ratio for the Firestorm Flux and then used the same overall ratio for the XXXT which resulted in a lower gear ratio. That dropped the temps on the motor to the acceptable range.
thzero
03.25.2010, 01:33 PM
Well I finally got batteries and all together and took the RC8T out for a run.
MMM/2200 using 50/16 gearing and 5S 5800MaH (Zippys). Motor was up to around 140 after some long high speed passes. Batteries were around 90. But the MMM fan came on.
Thoughts?
03.25.2010, 02:59 PM
Doesnt sound too bad- what speed is that geared for with your setup exactly ( I would pump the numbers into the calc but Im lazy :P )?
Doing speed runs will heat things up a bit more vs normal bashing argueably, so I wouldnt be too concerned- just allow the motor and esc to cool down every now & then between runs, then bash/ speed run some more. :)
thzero
03.25.2010, 03:26 PM
52.62mph is what BG's says. I was going with it because people were mentioned it was a good combo.
Was gonna try going down to 50/14 which is a "46.05".
I will say though, belting the tires (I did the insides with gorilla tape and outsides with 50lb test fishing line) means very minimal if any ballooning!
