My HPI MT2 reborn (as electric of course)
IGT_7x
IGT_7x's Avatar
My HPI MT2 reborn (as electric of course) - 05.28.2010, 08:35 PM
Here she is, my reborn HPI MT2 now sporting a brushless setup & an extended chassis. As you can see it's almost as long as my Slash. Now let's see how she performs
ID:	8929   Click image for larger version
ID:	8930   Click image for larger version
IGT_7x
IGT_7x's Avatar
05.28.2010, 08:36 PM
More pics
ID:	8934   Click image for larger version
ID:	8935   Click image for larger version
05.28.2010, 10:16 PM
Thats pretty sweet, Im guessing custom or aftermarket chassis + stretched too. Mean looking slash aswell
IGT_7x
IGT_7x's Avatar
05.28.2010, 10:33 PM
Thanks, yes it is custom, actually it's from CKRCcrawlers.com, they have it as a kit. I just went ahead & used a Sidewinder ESC & Velineon motor, it should be enough since I'll be using 2-3s lipo. As far as the Slash it's been one hell of a truck, tough as nails.
ta_man
06.01.2010, 07:48 PM
Did you do that klugy thing with the Traxxas sliders for the front or find a better way?
reno911
Smelly Nitro meet your maker!
reno911's Avatar
05.28.2010, 10:46 PM
Hey CKRC stuff. Glad yours turned out, and you got everything in the shipment. I worked there for a week. Literally, Jake is a bit of a skiddish dude. It has to be tough, because of the way Jake races... He makes some good stuff, and it is the best LHS in my area. However, do to a sticky situation I hold back my urges to shop local.
swiftneed
swiftneed's Avatar
05.28.2010, 11:27 PM
Hey I have two of those Hpi Mt2 I will be digging them up and trying a conversion and what were the necessary parts and anything custom?OK found it said sold out but requires quite a bit of work not like RCM drop in and go
  • RCM XT8 MMM NEU1521 1Y AKA TIRES HITEC 7955 TG 6S
  • MBX6T MMM CC 1518 HITEC 7955 BRAKE 5645 MG 6S LIPO
swiftneed
swiftneed's Avatar
05.28.2010, 11:31 PM
I didnt see anything that said conversion can you let me know under what
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
05.29.2010, 12:31 AM
Both look pretty sweet, nice work !
reno911
reno911's Avatar
05.29.2010, 12:49 AM
Call them. It is no longer on the website but I am pretty sure they still have the custom lower and top plate for the chassis. As for everything else. I could probably get you the parts that are need if I asked what they were.
If they say no PM me I can check when I go in next time.
reno911
reno911's Avatar
05.29.2010, 12:50 AM
Nevermind it is still there.
http://www.ckrccrawlers.com/ckrcmt2s...on-p-2450.html
IGT_7x
IGT_7x's Avatar
05.29.2010, 02:44 AM
The kit will include everything you would need for the conversion, but it does require a little bit more work (a dremel helped a lot) but once you're done it'll be sweet Once you get the kit the instructions can be found here: http://www.ckrccrawlers.com/infockrc...on-p-2453.html
swiftneed
swiftneed's Avatar
05.29.2010, 11:40 AM
Thanks
IGT_7x
IGT_7x's Avatar
06.01.2010, 08:03 PM
Yes I did till I find a long enough dogbone to replace it, but I've tested it & so far it's holding up.
