My final Lipo choices for Flux. What say you?
Freezebyte
My final Lipo choices for Flux. What say you? - 07.30.2010, 12:47 AM
Ok after spending way too much time going through Hobbking, trying to decipher all the menus and crap AND what actually was in stock, this is what I found that seemed like it work work well.
Do I go all out and get the new nanotech turnigys and go for the insane 6S power that i've never experienced before?
http://hobbyking.com/hobbyking/store...dProduct=11939
Or do I play it a bit safer/cheaper and get non nanotech with just 4S which im familiar with?
http://hobbyking.com/hobbyking/store...dProduct=10277
Or do I get this 6S non-nanotech Turnigy from the USA with higher C output?
http://hobbyking.com/hobbyking/store...dProduct=12936
I guess im stuck ordering from across the sea as the USA warehouses have squat in stock, so i'm gonna have to pay arm and leg for shipping. How long does this EMS Express to USA shipping take anyway? Or should I just wait to get something better in like these?
http://hobbyking.com/hobbyking/store...dProduct=12937
07.30.2010, 01:36 AM
If you are happy with 4s I would stick with 4s. People are eating up flux trannys left and right on 6s.
You've got the right idea, any of the choices you are looking at would be adequate.
scarletboa
scarletboa's Avatar
07.30.2010, 01:56 AM
if i were you, i would just get the normal shipping for now and just wait it out. there is a major dilemma with shipping lipos through hong kong right now, which means shipping times are a little longer and it can be a pain but it is worth it.
the 30c hardcase packs you picked are only a few bucks cheaper than the 40c version. i have the 30c version and they are incredible packs, so the 40c should be even better.
if i were you, i would get the nano-tech 3s packs and gear your truck 18/47. that's what i run my flux at on 6s and it is a very cool running setup that has great runtimes and better speed than stock on 4s, but at the same time, the motor runs nice and cool and the batteries are less stressed.
i'm sure your flux experience will be a lot better with better batteries and duel chargers. it will take about 80 minutes to fully charge those 3s packs, but it will be well worth the wait.
one more thing, about the chargers, there are much better options that will allow you to charge your batteries in 40 minutes or less and it won't cost much more. all you will have to do though is get a power supply and more capable chargers. it is not difficult at all and you will thank me once you get it set up. also, you will only need 1 wall outlet for both chargers.
here's what you should get: two of these and one of these. you will only need one for both chargers. you will be able to charge both of your 2s or 3s packs at 10a each.
Freezebyte
07.30.2010, 02:34 AM
There outa stock for the 40C or I woulda gotten them and I can't wait two weeks, I have no patience.
PBO
RC-Unobtainium
PBO's Avatar
07.30.2010, 03:32 AM
No Maxamps lego cells?
Enhanced Rustler 1515 1.5 MMM
Losi 8ight-T
Freezebyte
07.30.2010, 03:33 AM
PBO, WTF is your avatar of, its disturbing
And no maxcraps
Safe gearing for 6S on Flux?
Freezebyte
Safe gearing for 6S on Flux? - 07.30.2010, 04:18 AM
EDIT: New thread
nitrostarter
nitrostarter's Avatar
07.30.2010, 08:04 AM
I think if you look back in your original thread about getting another Flux, linc gave you the suggestions to go 6s and a gearing choice...
http://rc-monster.com/forum/showpost...5&postcount=21
N. Rustler conversion
JThiessen
JThiessen's Avatar
07.30.2010, 09:38 AM
Harold, where the heck are you getting your info from. I can't recall the last time I saw a post about someone eating up a Flux tranny.
Ok, after thinking hard about this, I really wanna try and experience 6S on my 2nd Flux. My first Flux did have plenty of go with 2S 6000mAh 28C SMC but now I wanna see first hand what 6S is like on this bad boy. After much research and forum searching, im aware that dropping the pinion gear down a few teeth will help reduce strain on the Lipos and reduce heat on the ESC and motor.
I plan on getting either one of these for 6S power. Any input?
Should I change my stock gearing from the 20/44 and go to 18/44 or should I go even lower? I wanna be able to still go faster then 4S at 20/44 but I don't wanna blow my ESC either cause I will be driving in variety of conditions while bashing and jumping.
Thanks all for your input and patience my last few threads, I just want to make an informed decison
Get the Nano tech one. Why, cheaper. But really, you probably wont notice the difference if you bought both of them. The 30C is actually more than enough for the truck - especially for bashing.
PBO
RC-Unobtainium
PBO's Avatar
07.30.2010, 05:26 AM
I have no idea...I thought it looked interesting. Like the little guy knows too much and his head pops off? I get avatar envy when I'm on RCM
UPS is a couple of days from HK, if you don't mind the extra cost? FWIW, I generally favour 4S bashing/jumping & keep the 6S for speed runs or wide open spaces
Losi 8ight-T
nitrostarter
07.30.2010, 10:14 AM
Might have to watch the dimensions on the nanotech packs. They are typically longer packs.
then again I can't recall the dimensions of the Savage battery boxes.
JThiessen
JThiessen's Avatar
07.30.2010, 11:04 AM
The Flux trays are quite long. My SMC 6K's fit with room to spare, and those are long packs too.
reno911
Smelly Nitro meet your maker!
reno911's Avatar
07.30.2010, 10:46 AM
I would go with the Nanos.
If ordering from hobbyking look into there chargers. They have similar chargers to the Hobbypartz at a better price. Since the shipping is outrageous make it worth it.
http://hobbyking.com/hobbyking/store...idproduct=6478
bigboi146
Multi Tasking
bigboi146's Avatar
07.30.2010, 10:51 AM
Why don't you try 5s? It''s right in the middle.
Freezebyte
07.30.2010, 10:52 AM
I dunno how to do that
