Go Back   RC-Monster Forums > Support Forums > Novak
hv motor sensor wire replacement
dracbec
hv motor sensor wire replacement - 08.21.2010, 02:32 PM
anyone know who to take the hv motors apart so i can remove the sensor wire and solder a new one on?
thanks
ta_man
08.21.2010, 11:37 PM
thanks
This is one of those cases where, if you have to ask how to do it, you probably don't have the skills to get the job done once you have been told how. But just in case, here's how:
Remove front endbell and rotor
Remove the rear bearing cover
Unsolder the stator coil leads
Remove the rear endbell
Remove the sensor board
Remove wires from sensor board
Solder new wires to sensor board
Reverse the rest of the disassembly process.
dracbec
08.22.2010, 02:18 PM
i have the skill just wasnt sure if i had to desolder the stator or now
BLUESTAR502
12.30.2010, 02:08 PM
Listen to mr i know everything. The only way hes going to learn is by doing it
whitrzac
Can't catch this...
whitrzac's Avatar
12.30.2010, 06:28 PM
please GTFO
BLUESTAR502
12.30.2010, 06:55 PM
Just say what you got to say don,t use initials.the guy was lookin for help and you have to give him some wise ass answer.typical jerk off
whitrzac
Can't catch this...
whitrzac's Avatar
12.30.2010, 07:21 PM
why are you here??
