The Gyro is worken Sweet !
radioman193
radioman193's Avatar
The Gyro is worken Sweet ! - 05.17.2011, 01:54 AM
Just Fix It !!!
I have been into electronics for 30+ years
and am a licensed Electronics Technician for over 26 years now.
  Send a message via AIM to radioman193
brijar
Knowing You're Hooked on RC: Priceless...
brijar's Avatar
05.17.2011, 02:00 AM
Nice! Which gyro is that and how exactly do you tune it? My friend bought a heli gyro to try and help his drifting, but it doesn't work very well at all.
REVO 3.3 Conversion: 3906 trans, CC 1518, MMM, 6s Gens Ace 5k 40C, LST Diffs, Summit shafts
Slash 2x4 LCG
Two Slash 4x4s
Rustler
radioman193
05.17.2011, 02:02 AM
you can get them on Ebay for like $20 or so.(ek2-0704B)
This is the one that i got BUT you will NEED a Third Ch for this one.
for usen just your 2ch radio you would want this one
ek2-0704 for 2ch radios you cant turn it off.(but its hard to find this one now)
For My radio all i needed to do was....
just plug it in to Ch1 on the RX
the yellow wire to Ch3 on the RX
Flip the switch on the Gyro to REV
turn on the Rc.. Wait for the Gyro to set its self about 3 seconds
on my Tx my datarate for ch3 is set to 28%
!!!! DO NOT GET IT WET !!!!
unless your good with electronics you Could take the Gyro apart like i did and Coat the boards in it COMPLETELY
with Epoxi
i even covered the Delay and Limet controles with epoxy.
i set the gyro limet to full and delay to its lowest BEFORE doing the Epoxi waterproofing.
DON'T cover the NOR / REV switch as you might like to still use this at some point in time.
this is the Epoxi that i use to waterproof with
Dont mount the Gyro in the CENTER of the Rc!!
Here is a photo of my Chassis and you can see were its mounted at.
Just Fix It !!!
brijar
brijar's Avatar
05.17.2011, 02:24 AM
His looks just like that first one but says Hobbyking on it. I didn't know what the 4th yellow line was for, but I guess it's for the 3rd channel port. He just got a 3ch radio, so everything should be good to go! Thanks a lot, hopefully it will work as well as yours.
Slash 2x4 LCG
Two Slash 4x4s
Rustler
radioman193
05.17.2011, 03:31 PM
let me know how it works for him..
Just Fix It !!!
05.17.2011, 04:07 PM
I don't understand this. I looked at the manual and it appears that the connector with the yellow wire JUST has that one wire in it, and it's a signal wire, not power or ground. What happens if you don't look it up? Hooking it to an unused CH3 receiver input seems redundant.
From your directions, it appears that the red/black/white cable carries the corrected servo signal and power and ground.
I could understand the need for the yellow wire if that was the one that needed to be inserted into CH1 (steering).
radioman193
05.17.2011, 05:22 PM
the Chinglish "manual"
the Gyro will not lock unless you have the yellow wire on a Ch.
and is for the Gyro trim...
the gyro takes its trim data off the yellow wire and will not initialize without it.
even if you don't use Ch3 on your Rx it does have data on it
as long as the gyro can see data on the trim line it will initialize
you just wont have control of the gyro and how it works.
if I use my 2Ch TX on this Ch3 data is +100% by default
and the Gyro is Crazy sensitive and i have No control over it.
but i use my 3Ch TX All of the time.
here is how its set
the ek2-0704 gyro is a Basic gyro and don't have a trim line
you can only set or control the sensitivity by the control on the gyro
Hence you can use it on a Rx with only 2Ch
The ek2-0704B is a Pro gyro with trim control.
yes a "default" mode without hooking the yellow wire would have been nice but no such luck.
But you have More control with the trim ......
you can control just how much Gyro you want from No Gyro to Crazy sensitive
just by setting the Ch3 Data rate and trim.
on mine i have my Limet set to MAX
Delay set to its MINIMUM
and the Switch set to REV
I hpoe this was a help to ya..........
Just Fix It !!!
Semi Pro
Semi Pro's Avatar
05.17.2011, 06:51 PM
great post, i have allways wanted to try a gyro, for $20 i cant say no
radioman193
05.17.2011, 07:34 PM
I'm Not Sure How It Would Hold Up Under Hard Bashing (Stock Like It Is)
My Gyro Is Filled With Epoxy
So I Don't See Water Or Vibration Hurting It...
As I Have Been Jumping And Crashing With It And It Still Works Just Fine.
And When I Say Crash Its More Like Major Whiteout 40+ At The End Of The Street Turned The Wheel To Quick And Did A Barrel Roll That Flipped It About 10 Times And It Turned Into A Cartwheel For Like 7 More Flips
Across The Intersection At The End Of My Street.
It Even Landed Back On Its Wheels And Drove It Back To The House Here.
The Only Damage Was 4 Big Cracks In The Body.
And The Gyro Is Still Working Fine.
So It Can Take The Stuff That I Dish Out To It.
Just Fix It !!!
josh9mille
josh9mille's Avatar
05.17.2011, 11:18 PM
So what exactly does the gyro do in a land vehicle?
05.17.2011, 11:28 PM
hpi was first to venture into land based gyros with it's "d-box" drift assist system. It just helps the vehicle to auto correct and continue in it's intended direction. Basically automatic counter steering.
brijar
brijar's Avatar
05.18.2011, 12:47 AM
It'll help you go straight on a slick surface like gravel or loose dirt, especially in a rwd vehicle. It can be tuned like the Dbox, I think, to help you drift as well.
Slash 2x4 LCG
Two Slash 4x4s
Rustler
radioman193
05.18.2011, 01:23 AM
it just helps you in steering and AWESOME for (Drifting)
you let the Gyro do Most of the Correcting as its A LOT faster than you could Ever be.
it keeps you pointed in one direction for the most part.
you can see in the video when it was turned off a few times on the curve the tail would just come up around to the front ....
Plus Under Full throttle takeoffs the rear of the truck would slide one or the other direction it will help keep this to a minimum..
I am not saying that the gyro will KEEP you from spinning out will be a 99.9% improvement .
ALL spin outs START Before one Even starts notice it or See it
and the Gyro is on the job BEFORE you even notice it correcting.
the video is a little drawn out at the start as i had a few people
saying that the gyro would mess with you on a hill or flipping in the air
but as you will see it don't.
sorry about the LOW audio in this Video
the mic on the camera is Under the tripod mount.
will say this it DONT Help you learn not one bit IN FACT it makes it harder for you when you Dont use it After usen it.
and with it you can do things you CAN'T do without it
I dont think there are alot of people here that can take that turn in that driveway at 20+ on lose stones and Holes .
A a human being can not Respond that fast.
Just Fix It !!!
brainanator
brainanator's Avatar
05.18.2011, 02:04 AM
built an autopilot for one of my professors (college credit for playing with an RC plane FTW!) and it had all the gyros, bells, pitot tubes, gps, and whistles. Pretty sweet stuff.
05.18.2011, 02:45 AM
butterflies rainbows open meadows and bunny rabbits
