soldering 9920 to 9xl
boggs
soldering 9920 to 9xl - 01.05.2007, 01:21 PM
What is the best way to solder your motor to the controller "wire to wire" Should you use a butt connector and solder it , or should tou solder the wires together directly?
jollyjumper
RC-Monster jumper
jollyjumper's Avatar
01.05.2007, 01:34 PM
use 5mm gold connectors for ease of things.
losi 8ight-t
xray xt8
neweuser
neweuser's Avatar
01.05.2007, 01:52 PM
Yup 5.5mm connectors are the way to go for this. Mke carries them ;)
remie
remie's Avatar
01.05.2007, 04:14 PM
is it possible to use 4mm connectors?
because I've got those laying around.
Costum Traxxas revo Brushless
  Send a message via MSN to remie
neweuser
neweuser's Avatar
01.05.2007, 04:52 PM
They won't fit the motor. The motor should come prewired to 5.5mm females, so all you need is 3 5.5mm males plugs. They are about the best and easy to solder and give great connection!
jhautz
jhautz's Avatar
01.05.2007, 08:18 PM
Yes you can use 4mm connectors on your 9xl and 9920 if thats what you have. They should be fine.
I never had a problem with the 4mms. technically the 5.5 connectors will handle more amps but the 4mm never heated up or anything when I used them so they were fine.
I used 4mm for a while and then switched to the 5.5 only because the Quark came with 5.5 and it was a pain having some motors/controlers using 5.5 and some using 4mm. So I switched all of them to the 5.5s. Now I can swap motors from vehicle to vehicle with no hassles. Just plug and play.
to make it...
or break it...
Silent...But Deadly
phildogg
phildogg's Avatar
01.05.2007, 08:30 PM
I'm running 4mm on my 7xl just because the mm esc already had them and I had the males in my box already.. seem fine to me never hot..
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
coolhandcountry
coolhandcountry's Avatar
01.05.2007, 08:34 PM
If you solder directly You don't need a butt connector.
You can use one to make it look neater.
You can go with the 4mm plugs since you have them.
Peace!
Country
Help support the
Rc-Monster
Buy here
