my RCM crt.5
starscream
RC-Monster TQ
starscream's Avatar
my RCM crt.5 - 12.31.2007, 02:25 AM
Ha Ha
12.31.2007, 12:37 PM
I like shiney things, what motor and esc etc will you be using?
t-maxxracer32
t-maxxracer32's Avatar
12.31.2007, 01:15 PM
didnt you put this up for sale?
jnev
jnev's Avatar
12.31.2007, 01:54 PM
This is the one for sale. He just wanted to show pictures of it for those interested in buying it.
starscream
RC-Monster TQ
starscream's Avatar
12.31.2007, 03:47 PM
Ya, unfortunately I have to part with this one
When fully loaded I ran a mm on 3S Kokam 3200's and a Mega Motors ACn22/35/1
Needless to say, this was a beast with that setup.
I love the construction and durability of these trucks. I would highly recommend Mikes conversion chassis for anyone looking to convert thier crt.5 to brushless. Unfortuanately, I have several other projects going on so I have to part this one.
I am actually still working on a simple plastic spur gear solution for these trucks and should have an update very soon. I'll be checking the mail today to see if my stuff arrived so hopefully I have an update sooner than later.
I'll keep you posted.
Ha Ha
rchippie
rchippie's Avatar
12.31.2007, 07:23 PM
could you just use 1/8 buggy diff mounts like ofna or jammin ?.
REAL MEN RUN BRUSHLESS
starscream
RC-Monster TQ
starscream's Avatar
12.31.2007, 09:46 PM
There are several issues with using 1/8th scale diff parts.
The holes for the diff mounts may not line up correctly and since a 1/8th scale diff is longer, you would have to drill new holes in the front and/or rear to attach the 1/8th scale mounts. This would also cause you to have to use different size dogbones.
The output yokes are smaller bore and depth on the crt.5 so std 1/8th scale yokes are not compatible for this application. You could change to 1/8th scale yokes and dogbones on the F/R but these parts are heavier and really overkill for 1/10th scale trucks.
The crt.5 uses 10x15mm bearings so any combination of 1/8th and 1/12 scale parts won't be compatible.
So far there is no easy solution, until now
Well, almost now.....
I received some stuff for other projects today but nothing for this solution
Hopfully it comes later this week.
This solution should be drop in and go...
Once it arrives I'll have an update shortly after
Ha Ha
GO-RIDE.com
01.01.2008, 12:23 AM
I've had great results from just running hardened steel pinions. However, a plastic spur would be quieter when I’m running at the indoor electric track. I’m the only one running a nitro conversion at my local track so I get a lot of looks from the hardcore racers, but they are also surprised at how fun and fast the little .5 is.
E-8ight - Tekin RX8 2000kv/4S
