Emaxx Transmission Spur Wobble
Shane_744
Emaxx Transmission Spur Wobble - 02.25.2008, 09:35 PM
I have the Emaxx single speed transmission on a G3R chassis. Converting back to stock emaxx spur, 32pitch pinion etc.
When I tighten down the nylon nut for the slipper clutch it makes the spur gear offset. So when you spin it, you get wobbling action. Way too much for a brushless setup. When you loosen the nut, the spur somewhat "flattens out". I watched the input shaft and it doesn't wobble.
What gives? Anyone know a fix for this other than two washers, one on either side of the nut. Thanks.
"Anyone interested in grabbin' a couple of burgers and hittin' the cemetery?" Royal Tenenbaum
