dual brushless motors
drkros3
dual brushless motors - 02.13.2008, 03:44 AM
just had a question. if i use 2 brushless motors do i need 2 esc's or can the motors be wired together to go to one esc.
thanks
02.13.2008, 07:09 AM
two esc's...
nl12
nl12's Avatar
02.13.2008, 11:20 AM
Unless...
steveo
02.13.2008, 11:27 AM
depends on how big the motors are and what esc you are using , you could use up to 700 size motors on a evx esc.
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
02.13.2008, 11:32 AM
Why not just size the system properly for one motor and be done?
jhautz
jhautz's Avatar
02.13.2008, 11:58 AM
you could use one, but the motors would need to be identical and timed to each other. Not that easy to do, but its been done.
I agree. one properly sized motor is more efficient and just as powerfull.
to make it...
or break it...
Silent...But Deadly
02.13.2008, 12:32 PM
But two gets you 'cool' style points...
:P :D
drkros3
02.13.2008, 01:03 PM
reason for 2 motors is cause im going to start building a truck and im going to enter the worlds fastest rc car challenge.
ok and thanks you guys answered my question.
02.13.2008, 01:11 PM
Well, that does change things though, since you are building a truck for a speed record. To find a single motor as powerful as a couple feigao XLs, you'd want something like a massive Neu or lehner costing 10 times as much, and esc costing.... I wouldnt like to guess. JohnnyMaxxima has a Gorillamaxx based truck with twin 7XLs running on 5s each- and Bk9920s I think it was-that should be a good point of reference for you.
02.13.2008, 01:33 PM
steveo - evx is not a brushless controller it is a brushed controller...
Jef - I guess you could ensure that the rotor was at exactly the same point... I suspect it would be difficult to achieve with variation between motors etc
MetalMan
MetalMan's Avatar
02.13.2008, 01:44 PM
Dual BL will not have that much of a gain over single BL, considering the extra weight involved. With dual BL, you pretty much need twice the batteries as a single motor.
My Savage will be entering the competition, with a single KB45 10XL (1200 kv) running on 10s2p A123, with a CC Phoenix-HV110. It's geared 20/46 with a center diff (no tranny), for a theoretical top speed of about 65mph. I haven't reached top speed yet because the suspension is too soft and the oil in the center diff isn't thick enough.
drkros3
02.13.2008, 08:12 PM
ok now would a xl motor push our more power then a L motor?
MetalMan
MetalMan's Avatar
02.13.2008, 09:29 PM
For continuous usage, yes. At the same power level, a shorter motor will generate more heat.
drkros3
02.13.2008, 10:12 PM
so if im only using it for a little bit of time could i use a L motor.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
02.14.2008, 02:30 AM
i would stick to one larger motor
what are you running this in?
a large Neu motor should work wonders for speed records
