Best way to secure the pinion gear?
fkadir
Best way to secure the pinion gear? -
02.15.2008, 10:05 AM
Hi Guys,
Whats the best way to secure the pinion gear to the shaft?
I have tried using locktite but the pinion gear still became loose after about 30 mins of bashing.
fkadir
2
Dafni
02.15.2008, 10:17 AM
Locktite, flat spot on the motor shaft, and the kung-fu grip on your wrench.
Dafni
Visit Dafni's homepage!
Find all posts by Dafni
3
02.15.2008, 10:36 AM
Yeah, the flat spot is an obsolute necessity IMO. If it's a Neu, cover the end holes with tape or something and then use a dremel sanding wheel to grind the flat spot.
Visit BrianG's homepage!
Find all posts by BrianG
Linear Mode
Switch to Threaded Mode
