Rustler on 9s lipo -
03.21.2008, 12:03 AM
Here is my next fill-in project. I like to have easy to finish projects to fill my time when I am bored with the bigger ones.
So I have a rustler, with all rpm parts, and a vxl internal, stock cased tranny. Plan to run jato anaconda rears all the way around (I already ave them) I will do the hpi rush front arm swap, to get equal track width front and rear.
Power will be 3 maxamps 2100 3s 20c packs in series, thru a kontronik 30-10-32. Supposedly the esc is good to 43v, and has a car mode. Motor will be an aveox 36/3/24. It is a 1300kv motor that is about halfway between a s and l can motor in size.
Gearing will be 18/54 to start. That should be good for about 60. I can swap to mod 1 gears and go as far as 25/36. That (125mph) may be a bit much though...
I will start with as many stock parts as possible. The chassis will be modded to accomodate the 3 packs. Not sure if the stock tranny case will be any good. I do have the upgraded bearing carriers, and a dogbone type drive setup.
Any ideas, or thoughts about this?
