maxamps 10,000 mah loose cell??
mk351e
RC-Monster just don't get it
mk351e's Avatar
maxamps 10,000 mah loose cell?? - 04.15.2008, 09:57 PM
well, this is a hard deal to pass up. $35 for a single loose cell, 10000mah. BUT, will it be good enough to blast a Neu powered Muggy to over 60mph?? I would build a 6S pack. here's the specs:
10000mah Capacity
3.7 Volts
59mm X 155mm X 10mm
Maximum Continuous Discharge 100 amps
Burst to 200-300 amps
200 grams
I know it won't be the best battery, but wow would it be cheap! I don't have anything yet, so I know the question is vague, but what do you guys think? Can I hit 60 using a 6S with these cells?
