The 6400Mah 2p2s skyvolt packs are comparable in price to the Scorpion and Balance Pro packs, with none of the built in benefits. The charger is abot $45 .00 more than the Scorpion charger.
The product description says, "To charge Skyvolt Packs, disconnect packs from the Module and charge them individually using the Skyvolt 6S Charger". I looked for a manual on the
FMA site. Not published there as of today. I was under the impression that these packs offered the same safety and convenience as the Scorpion packs, but at higher capacities. They require seperate charge protection and discharge protection modules, about $60.00 a throw.
Other than voltage availabilty to 22.2v and up to 9600Mah, the biggest benefit is the ability to fast charge. Wow, 22.2v and 9600Mah in twenty minutes, safely. Cha-Ching!:eek:
