batery amps
jlustig83
Brushless is the future now!
jlustig83's Avatar
batery amps - 06.10.2008, 10:14 PM
would 10 nimhs have more amps than a 12volt car battery . i dont know which one would last longer in an electric motor cycle
jlustig83
jlustig83's Avatar
06.10.2008, 10:17 PM
oh and the motor is only 200 watts with a 12 amp contoller
06.10.2008, 10:31 PM
No...
Patrick
Patrick's Avatar
06.11.2008, 05:20 AM
I think car batteries are usually ~40 to 50 Amp hours, maybe a bit more or a bit less depending on the size of the car.
10 nimh cells will give you 12 volts and 3.3 to 5 amp hours capacity depending on which cells you use.
A 10p setup (100 cells) will have similar capacity though. The nimh batteries would be a lot lighter, but probably 5 + times the cost.
Will a 12 amp controller be enough for a 200 watt motor? 12 amps at 12 volts will only be 144 watts.
tc3_racer_001
tc3_racer_001's Avatar
06.12.2008, 10:57 PM
i think he means a small sla... if this is still relevant
in which case 2-4p may be the same?
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
