I've gone the same route as you with my hyper, and I've been through many redesigns.
1. IMNSHO, the plastic Kyosho spur is junk. I was told it would seal fine; it didn't. I've heard of using the paper gaskets for it, I admit I didn't try those. Messing with the shims never worked well either, always was stiff to turn. The plastic teeth don't hold up well either, if you are going for better than nitro power, you're going to shear teeth. It's a kludge at best. I switched back to a hardened steel spur/pinion combination and that headache went completely away and has never come back.
2. The 12T, 13T and 15T pinions you will probably never use. 12 and 13 are too small, the 15 will probably give you heat problems.
3. Using your monster max with ccbec? Why? It's got one built in, and if you can tell the few extra tenths of a volt, you're a much better man than I am!
FYI, I'm still running my V1 MM with no CCBEC (on 6S) and I've had zero problems. Of course if you are talking a Mamba Max, then yep, you'll need a CCBEC.
4. Feigao 10L motor: In a word, no. I tried it, and didn't like it. I think you need an XL can for a 1/8th buggy if you want it to have some snap to it.
5. As for shims, you won't need 'em if you stay away from that plastic spur sillyness.
Trust me, you want the durability of steel. When you land a jump at full throttle or full brake, guess where all of the force of that goes? Yep, right in the teeth! I know you're not supposed to land like that, but that's how you save a bad landing.
Hope this helps you out and saves you from going through the same troubles I have. Personally, I think that 6S A123 and a 10XL can't be beat. I just posted a vid of my BL hyper 7 at the track the other day, you might want to check it out and see what you think:
http://www.rc-monster.com/forum/showthread.php?t=14291
