Feigao/Nemesis/Wanderer query
Sean
AKA Monkey
Feigao/Nemesis/Wanderer query - 08.20.2008, 10:50 AM
are these motors all exactly the same to the point if i wanted to run two i could run a nemesis 8L next to a Feigao 8L and one wouldnt be carrying the other?
cheers
Cars:
Kyosho Lazer ZX-5, 74MPH Pictures
E-hyper-7 Pro UK
EB4 s3, STS28
My Cars and Projects
  Send a message via MSN to Sean
brushlessboy16
brushlessboy16's Avatar
08.20.2008, 10:58 AM
same exact motor-differnet color
08.20.2008, 11:08 AM
But a waste of time you are better off selling the 8L and getting a single better bigger motor...
Sean
AKA Monkey
08.20.2008, 11:36 AM
id have to sacrafise RPM's to do that ;)
thanks for the reasurance brushlessboy16
Cars:
E-hyper-7 Pro UK
EB4 s3, STS28
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
08.20.2008, 01:12 PM
First thing you have to learn is that an electric motor doesn't work like a nitro motor. You don't need RPM to get speed, that's what gearing is for.
Slow down a bit and let us help ya.
Sean
AKA Monkey
08.20.2008, 01:14 PM
i now next to nothing about nitro and a fair bit about electic sure i could gear it up but my old reliable MM wouldnt be so reliable any more
Cars:
E-hyper-7 Pro UK
EB4 s3, STS28
08.20.2008, 11:49 AM
Yes but gear up - I presume you are working on an emaxx or esavage? Post up your setup...
Why not look at a Medusav2 60mm 2000kv... on 4s geared 22-24/66?
Not only do you save the motor but you also save buying an esc
Sean
AKA Monkey
08.20.2008, 01:13 PM
its a hyper 7 to enter in the worlds fastest RC max speed with that motor assuming its does the rated 2000 and assuming no losses 24/44 gearing is 100mph
problem being im using a MM ESC and it wont supply the amps it would need
hence doubling up as i dont fancy my chances of getting a MMM in time
Cars:
E-hyper-7 Pro UK
EB4 s3, STS28
08.20.2008, 01:17 PM
Fair enough - Pure speed comps are very different in terms of setup - I would look at 2x medusa 50 3300's on MM's on 4s with rx battery...
PS is that zx5 jump digitised - a lot of pixelation around the car in the air...
B4maz
08.20.2008, 01:33 PM
It would be a lot easier to use your MM in your ZX-5 instead of the big Hyper 7. Youre gonna pull a lot of amps in your Hyper 7 and you can get more speed out of the zx-5 with a less powerful setup. Are you on Fast-RC forums?
Sean
AKA Monkey
08.20.2008, 01:28 PM
i already have an 8L though and they will be capble of going faster than im aiming for
cheers for the input guys much appretiated
Cars:
E-hyper-7 Pro UK
EB4 s3, STS28
Sean
AKA Monkey
08.20.2008, 01:40 PM
zx-5 wasnt going any faster than 74mph the plastic diffs saw to that went through about 4 diff sets at tonys (guy from fast-RC's) event last year.
im registered on it but havent really used it for a while been busy.
Cars:
E-hyper-7 Pro UK
EB4 s3, STS28
Sean
AKA Monkey
08.20.2008, 01:56 PM
just been browsing the site it appears i still hold the record for electric scale appears i have a title to defend lol
Cars:
E-hyper-7 Pro UK
EB4 s3, STS28
Sean
AKA Monkey
08.20.2008, 02:10 PM
would anyone like to put a number on how much current my 8L's will be drawning?
cheers
Cars:
E-hyper-7 Pro UK
EB4 s3, STS28
08.20.2008, 02:25 PM
Dual 8L motors geared high for top speed can draw quite a bit. I would make a rough guess at about 20-25A average with 150A+ bursts.
