MM LiPo Cutoff Issues
bensf
MM LiPo Cutoff Issues - 08.19.2008, 05:06 PM
I'm trying to turn on the LiPo cutoff and when I turn it on, the controller stops working. It will work when it is set to No Cutoff or 5.0v, but not anything else. My batteries are above the cutoff voltage. It seems like its not arming, but I can hear the beeps that says it is. . .
08.19.2008, 05:14 PM
Are you programming it via the usb, or buy the remote? I would check to make sure you have the lastest software and firmware, as there was an issue backalong with one of the updates stoppin the esc from working properly when a custom lvc setting was used, or some't like like..
bensf
08.19.2008, 05:31 PM
USB. Firmware is 1.17.
bdebde
That's All Folks!
bdebde's Avatar
08.19.2008, 05:33 PM
Castlelink version?
bensf
08.19.2008, 07:03 PM
Castlelink ver 3.1
jhautz
jhautz's Avatar
08.19.2008, 07:52 PM
what voltage are you ruinning? The newer MMs dont like to run 5s with the LVC turned on.
to make it...
or break it...
Silent...But Deadly
brushlessboy16
brushlessboy16's Avatar
08.19.2008, 08:10 PM
use a custom setting
bensf
08.19.2008, 08:54 PM
Its an older one which I was told ran great on 5s. I have the LVC set to 12.4 and I also tried 12 and neither worked.
entjoles
08.19.2008, 09:33 PM
i had to drain a little battery (when fresh off the charger) to get it to run on 5s
what is your pack voltage at?
you may want to set your lvc to the correct input! the 12.4 or 12 is for 4s
try it on custom and at 16v
bensf
08.19.2008, 09:36 PM
It was at 7.6 for each. I also tried and it wouldn't work with 2s either. . .
I'm trying to make it work with 4s, not 5s BTW
entjoles
08.19.2008, 09:38 PM
are you using a external battery or a external bec?
on 2s is the red wire back in the plug to use the internal bec?
entjoles
08.19.2008, 09:41 PM
if its my old one......ill buy it back , im in need of a esc. for my truck
bensf
08.20.2008, 01:14 AM
yea it is. ;) I'm using a CCBEC with it.
bensf
08.20.2008, 01:41 AM
http://www.youtube.com/watch?v=Dp4XGeb81Z0
And a video. 1st try is with no cutoff, second is with 12v cutoff.
bensf
08.21.2008, 01:36 PM
Still have no clue how to fix this. . .
