Originally Posted by Dagger Thrasher
I just installed my castle 5.5mm connectors on my neu motor & castle esc & i noticed something. when put the two plug halfs together there is a small gap between the two ends . I pushed as hard as i could but they will not go on anymore . Has anyone else noticed this ?.
Probably there was a bit on one of the CNC turning centers that dulled -- and it didn't alarm until sometime after it built a few bad connectors -- and then they were missed by QC (just one thousandth of an inch in tolerance can cause the issue you described...)
I'd suggest you call tech support and just get them to send you an AWR. Tell 'em Patrick sent you.
