broken screw
Basketti
broken screw - 11.23.2005, 05:44 AM
I broke a screw and now its stuck in my flm hybrid bulk. Its one of the ones that goes through the chassis to the bulkhead. anyone got any ideas on getting it out?
Serum
Serum's Avatar
11.23.2005, 05:53 AM
Now, that can be a pitta... How deep is it in?
Perhaps you could use FLM's warrantee on this one?
Basketti
11.23.2005, 06:10 AM
well i would say a good 5-7mm is stuck in the bulkhead, and it starts about 2mm from the top so i cant grab it with some pliers. I didnt use thread lock on it so if i could stick something on it it shouldnt take to much to get out. And what makes it worse is i've only ran my truck about 5 times with these on. i hope the warrentee covers it that would be great.
Serum
Serum's Avatar
11.23.2005, 06:22 AM
are they 2 mm out or in?
If they are out, you can use a thin dremel tool to make a cut and you can screw it out with a flat head screwdriver.
Basketti
11.23.2005, 06:26 AM
Sorry I ment they are 2mm in.
nbcaznmaster
RC-Monster Cult Member
nbcaznmaster's Avatar
11.23.2005, 07:31 AM
ouch, hate it when stuff like that happens.
~~~~~~~~RC Garage~~~~~~~~
LSP-R - Picco .26
Custom E-Revo - Warrior 9920/Feigao 9L
Nitro Revo - .18tm
  Send a message via AIM to nbcaznmaster
dabid
11.23.2005, 12:54 PM
You might still be able to do the Dremel trick, but it'd make a nasty mark on the surface.
nbcaznmaster
11.23.2005, 01:44 PM
probbably would void teh warrenty too...
LSP-R - Picco .26
Nitro Revo - .18tm
squeeforever
squeeforever's Avatar
11.23.2005, 03:50 PM
not likely.
-corey
Basketti
11.23.2005, 11:17 PM
I might just run it like it is with 3 screws. it shouldnt make that much difference would it?
rchippie
rchippie's Avatar
11.24.2005, 09:44 AM
If you dont think you can get the screw out, without messing up the bulk. You can take it to your local machine shop for a few bucks they can get it out without messing up the threads on the bulks.
REAL MEN RUN BRUSHLESS
Serum
Serum's Avatar
11.24.2005, 09:47 AM
Any idea how they do that Hippie?
coolhandcountry
coolhandcountry's Avatar
11.24.2005, 09:50 AM
Do they make a little bitty easy out for such a problem? What if you flip the bulk head over and put a small drill on it and drill from the under side. If it is not in tight the drill will unscrew it. Just a suggestion to try.
Peace!
Country
Help support the
Rc-Monster
Buy here
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
11.24.2005, 10:47 AM
You need a small EZ out or extractor bit to get the screw out. No loctite makes it a much easier task, too!
It won't be terribly easy, though, because it is so small in diameter.
My guess is the "no loctite" caused the screw to break in the first place, actually! If the screw backed out while you were running, I could see it breaking pretty easy from an impact.
rchippie
rchippie's Avatar
11.24.2005, 02:50 PM
Very carefully :L: . They would be able to drill the screw exactly in the middle. Which would make it eaiser to get the screw exstractor a good grip. I f you cant cut a slot in the screw i would have a machine shop do it. Sinice the screw is so small.
