help i think my mmm is dead
petewalford17
Thumbs down help i think my mmm is dead - 09.25.2008, 09:08 AM
this is my first this is what happend i was happy running putting lots of dust in the air very fun wahoo . then my emaxx servo stoped but the motor still ran. so i switched it off then back on it droved forward a copule of feet and just stoped switched off on and it did same. switched it off on a third time it bleeped like normal but then nothing. got home checked receiver wire tried it 4th time nothing. then i got a different receiver. tried it 5 th time i got first set of bleeps then nothing. i think it could be the bec but not shore if you lot have got any ideas or the same just say. also tell me to send it back if you lot think its one of lots.
thank you pete
if it dont go fast chuck more money at it
cwallis
09.25.2008, 11:01 AM
I would send it in. That is basically what mine did when it died. I would send it in so you can be in line to get the V3's when they are done, I have a feeling they will be flawless. Castle has to get it rite this time.
jhautz
jhautz's Avatar
09.25.2008, 11:10 AM
do you have a volt meter you can check the output voltage of the bec when the MMM is turned on? I sounds ike what happened to mine when it died. Sometimes it woked and sometimes it didnt. When it worked it would work fo a few seconds and shut down again. The voltage on the internal BEC output was varying from 2v to 6v depending what it felt like doing at that moment.
If you can check the BEC output voltage, but thats what it sounds like to me.
to make it...
or break it...
Silent...But Deadly
petewalford17
Talking 09.25.2008, 12:58 PM
just tested the bec with a voltmeter it says about 6v the i switched it on off a couple times and the 5th time got smoke from my servo unplugged servo it powed up fine with both sets of bleeps put it on the floor ran it back and forth lots of times and it works fine. so all i need is a new ace servo at £50 or $90 but at lest its not the mmm.
thank you for the help
tc3_racer_001
tc3_racer_001's Avatar
09.25.2008, 06:40 PM
ive heard many failures from digital ace servos in te recent weeks. i suggest u try another brand :) watch out for hitec, their products are awesome but i had trouble finding an alloy servo horn... futaba / airtronics seem the most supported over here... may be different in the UK.
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
George16
Supermaxx
George16's Avatar
09.25.2008, 08:23 PM
They came with my 5955TG servos. You can buy them from Tower too.
http://www3.towerhobbies.com/cgi-bin...tec+servo+horn
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
JThiessen
JThiessen's Avatar
09.25.2008, 09:28 PM
Yours came with one? Mine didnt, and neither did the one we picked up for my B'in law.
jordan...
one.five.two.seven
09.25.2008, 10:59 PM
Same here, I just got a black Dynamite alloy horn for $4 or something. I didn't even get the different colored plastic horns, just black
George16
Supermaxx
George16's Avatar
09.25.2008, 09:48 PM
Yes sir!!! All three 5955TG servos I bought have the usual plastic (red, white, black) horns plus the blue aluminum horn.
Revo with OS .18TZ
azjc
09.26.2008, 07:53 AM
Impakt also has them
tc3_racer_001
09.26.2008, 07:33 PM
thats international, doesnt do much good when your at te track and the mini hobby shop has only futaba ones... someone else there had one i could buy so that was good... also international shiping makes it really not worth it, id rather bay $10 locally than $5 + 10 shipping!!!
but i never got anything with my servo, i managed to strip my cut down plastic one from the box which i never thought id do... anyhow.
hyper 8.5 pro SOLD!
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
