Neu 1512, 1.5d (3300Kv) on 4s in crt.5
david lamontagn
Question Neu 1512, 1.5d (3300Kv) on 4s in crt.5 - 10.21.2008, 10:17 PM
I want to make a killer bashing crt.5 and i have a Neu 1512, 1.5d, a MMM V3 on the way, and presently, i have a TP 5000, 3s, but i want to go with 4s.
Do you think that this motor will do the job just fine on 4s or should i stay with 3s and put a bigger pinion???
I know that this motor pull alot of amps (135A) so i consider that run it on 4s will lower the temps and give me longer run time???
But i have a Neu 1509, 2.5d (2700Kv) too, maybe i'am better to put this 1509 on 4s in the little crt.5 and keep the 1512 on 3s in my slash??
Don't know what to do
Thank you!
10.21.2008, 10:41 PM
i think either will be fine - i'm not sure you will actually get that current as the motor is not going to be stressed in a crt.5.
My 3300 kv 50mm medusa runs fine on 2-4s...
david lamontagn
10.21.2008, 11:07 PM
That's exactly what i'am think.
The crt.5 is under 5 lbs i think so this motor will have less load than on a truggy.
Thank you!
Snipin_Willy
Snipin_Willy's Avatar
10.21.2008, 11:25 PM
I'm using a 1509 1.5Y in my CRT.5 and I can't keep the front wheels on the ground, I don't see any reason for a bigger motor.
david lamontagn
10.21.2008, 11:38 PM
On 2s, 3s or 4s??
jhautz
jhautz's Avatar
10.22.2008, 02:12 AM
That 1512/1.5d is going to be one beast of a motor in a crt.5 Its a beast in a 1/8 buggy on 4s. Edumakated had his 1/8 buggy up to almost 70 mph on the 1512/1.5D and 4s.
You might want to make sure you have planty of tires on hand when you run it. I suspect you will be blowing them off the rims with very little effort.
to make it...
or break it...
Silent...But Deadly
david lamontagn
10.22.2008, 06:38 AM
I like to ear this
Ryu James
Ryu James's Avatar
10.22.2008, 06:48 AM
Thank you!
i run the 1512 1.5D Neu on 4s in my losi 8 and the thing flies and i get 30 minute run times. i highly recommend this setup. in a crt.5 it will really fly cuz it will be a lot lighter than my bugggy.
Jammin SCRT10 Neu 1512 1y
david lamontagn
10.22.2008, 08:02 AM
Good!! Hey Ryu James, which 4s lipo do you have???
I have Thunder Power since last year and i like this pack, but with the price of the Ziippy-R pack at UnitedHobby, i want to try this pack.
Finnster
KillaHurtz
Finnster's Avatar
10.22.2008, 10:57 AM
I too think that is too much motor for the .5. I had a 3100kv little LMT 1920 on 4S that could do over 60, and barely keep the front down most of the way. See the Utube vid in my sig to see. I detuned to a 2200kv 50mm medusa and its still a wheelie monster if I load it enough.
That 1512 may be about undrivable in a .5.
david lamontagn
10.22.2008, 02:38 PM
I think that i will try my Neu 1512, 3300Kv on 3s and see the performance and run time. i have an eagle tree so i will be able to monitor the amps drawn by the motor, and if it pull too much amps and the run time is too short for my taste, i will order a 4s pack.
I have my 1509 2700Kv on 3s in my slash and this little motor put alot of power in the slash and i think that the crt.5 is about the same weight than a slash.
My slash is 6.1lbs now, with the FLM tranny case, Koolflight UBEC, badlands tires and LX one shock.
Ryu James
Ryu James's Avatar
10.22.2008, 04:02 PM
i had the new Losi 4s hardcase pack but now have the thunder power extreme V2 and it is way faster than the losi pack. i highly recommend it!!
david lamontagn
10.22.2008, 05:06 PM
I run Thunder Power extreme V2, 5000mAh, 3s in my slash and love this pack too
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
10.22.2008, 06:13 PM
I think you really have to be insane to put a 1512 1.5D in a Crt .5, unless you are trying for the "fastest crt. .5." So I think you are better off with your 1509. It just doesn't make sense to take a car with a smaller footprint than a 1/10 st and have it be heavier and twice as powerful as a 1/10 st.
Area 52 Ranch Raceway
T.R.C.R.
phatmonk
RC carbon junkie
phatmonk's Avatar
10.22.2008, 06:17 PM
I had a crt.5 with a 1512/1.5d and ran 4s and it was simply awesome.Never got hot and it shredded tires highly recomended.
