roofles.
Mamba Max w/ Fiegao 9L - Series Harness? Or what? -
11.08.2008, 06:08 PM
I can't remember correctly.
I believe it's the series harness?
Where, the female deans/connector goes into the male ESC deans/connector, and the female deans/connectors is split into two deans?
Anyone have a good diagram? Or should I just pick one up from like GA?
roofles.
11.08.2008, 06:09 PM
11.08.2008, 06:13 PM
series
parallel
11.08.2008, 06:15 PM
roofles.
11.08.2008, 09:59 PM
So I'm looking for the series right?
Does the postive and negative go together.. right?
RC-Monster Stainless Steel
11.08.2008, 10:05 PM
depends. what batteries do you have?
roofles.
11.08.2008, 10:12 PM
For now, NiMHs, but have some hardcased 5000mAh 2S ones on hand. That I should be testing out sometime tomorrow.
roofles.
11.08.2008, 10:44 PM
Also included 3A-5Amp UBEC.
Now, I'm completely new to the brushless world, but what does the UBEC accomplish? And how do I wire it? With the diagram, I'm viewing that I should be splicing it into the ESC's Male Deans?
roofles.
11.09.2008, 03:14 AM
anyone?
11.09.2008, 03:51 AM
Reason: fix link
roofles.
11.09.2008, 11:43 AM
Are the series harness the same, even with NiMHs?
and
11.09.2008, 01:31 PM
This is not the Traxxas forum....
Read one of my FAQs, then the tutorials that follow them in the same threads- that will answer all your noob wiring and BEC etc questions in explicit detail
11.11.2008, 12:22 PM
ok will somebody ban this sucker please?
roofles.
11.09.2008, 04:39 PM
Too true Neil.
Actually, mikey said that, up above.
The FAQ is just so long :( Fine.
roofles.
11.09.2008, 04:44 PM
Actually Neil, since I'm only going to be running the 2S (x2) LiPos, I won't be needing the UBEC, will I?
Of course, if I was running 4S, I would need it.
Or is running 2 lipos in series doubling the cells, thus causing 4S? Or am I just gone stupid.
