Balancing Nue batts with TrakPower v-balance
mkrusedc
NeuMaxx
mkrusedc's Avatar
Balancing Nue batts with TrakPower v-balance - 11.23.2008, 10:46 PM
How do I balance a NeuEnergy 5s battery with a V-Balance from TrakPower? Is it as simple as plugging the NeuEnergy's tap into the V-Balance?
The NeuEnergy has a 6 pin female tap. The V-Balance has an eight pin plug. Should I put the tap close to the positive lead Like the TrakPower tap. That way the black lead will be on the same pin?
Thanks
