mamba 25 +4 cell lipo?
Semi Pro
Semi Pro's Avatar
mamba 25 +4 cell lipo? - 11.30.2008, 02:47 AM
so can the mamba 25 run 4cell lipo?
im sure it would need a bec and hv cap
i have a 3500kv hacker motor i want to run on 4 cell in my mini lst, if the mamba 25 can't do it whats the smallest esc that can?
thanks
stompingpede
11.30.2008, 06:46 AM
yes it will, my tekin mini rage ran awsome on 4s. and all the mambas will handle it.
himalaya
himalaya's Avatar
12.01.2008, 04:23 AM
Yes it will, just like the MM handles 4S perfectly with a BEC installed. I believe the major difference between Sidewinder and its bigger brothers is the number of MOSFETs mounted, which affects current spec, not voltage.
....What a Blue Sky....
Matthew_Armeni
Matthew_Armeni's Avatar
12.01.2008, 01:14 PM
Well if that's true, maybe I'll try 6s on it....
  Send a message via AIM to Matthew_Armeni
DickyT
12.01.2008, 01:58 PM
that will not go so well I think... I plugged 5s into mine after having GriffinRu
stage 1 mods done and it went up in a ball of flame.
himalaya
himalaya's Avatar
12.01.2008, 11:26 PM
I have to say you are so brave, man.
stompingpede
12.02.2008, 12:05 AM
5s worked on my mini rage when the pack was at nominal voltage.18.5. when i peaked the lipos 21v, it stuttered and the smoked. ran 73mph in 1.7 seconds using tekin mini rage with 8.0kv mini motor.
12.02.2008, 01:05 AM
Do you know that's 148000rpm?
Joe Ford
Castle's Chaos Corner
Joe Ford's Avatar
12.02.2008, 03:54 PM
No need to change the caps...they'll handle 4s just fine as long as you use a capable battery pack. I've run 4s on a 6800...stupid fast...stock up on diff sets. LOL
Joe Ford
Product Specialist
