need help with my RC8T
Ryu James
Ryu James's Avatar
need help with my RC8T - 12.24.2008, 05:28 PM
i am trying to setup mech. brakes on my RCM RC8t and the motor can rubs up against the brake discs before the spur and pinion can engage. is there a solution to this that i am not seeing?
ascbrakes1
ascbrake2
Jammin SCRT10 Neu 1512 1y
webman405
speedaholic
webman405's Avatar
12.24.2008, 05:32 PM
take a dremel to the brake disk?
on the last day of school, all my teachers said i was a smart cookie. if thats what they think, it's fine with me.
Ryu James
Ryu James's Avatar
12.24.2008, 05:36 PM
i thought of doing that but i would have to dremel quite a bit to make it work and already there is only 3/16" of the disc that touches the pads. if i dremeled it i would lose alot, if not all, of my stopping power.
i also considered changing to larger gears. the gearing on there is 16/50 and i would have to use probably a 17/54 or even 18/54 to get it to work and that is not gearing that i want to use.
wallot
wallot's Avatar
12.24.2008, 05:35 PM
if you use 50T spur you can get 54t one which will give you 2mm more and if that is not enough get larger pinion.
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
12.24.2008, 06:03 PM
Yes the brake spacer...
http://www.rc-monster.com/proddetail...rontmotorcover
Ryu James
Ryu James's Avatar
12.24.2008, 06:32 PM
sweet! thanks Arctik. i will just make my own. why didnt i think of that?
12.24.2008, 08:10 PM
That will not work because the rear disc is your problem- not the front which is what that cover will fix.
12.24.2008, 08:11 PM
Nevermind I am an idiot.
Ryu James
Ryu James's Avatar
12.24.2008, 10:53 PM
no, you are right. if the spacer is even almost the same size as the motor can, which it looks like it is, it still wont work because then the spacer will just hit the brake disc.
12.24.2008, 11:25 PM
The brake version is cut out to provide clearance for the discs - It works... Trust mike...
jayjay283
jayjay283's Avatar
12.24.2008, 11:27 PM
Yeah thats pretty much what Mikes brake spacer looks like
Metallover
RC-Monster Spudgunner
Metallover's Avatar
12.24.2008, 11:40 PM
You could also dremel the motor fins if there is any room to do so.
Ryu James
Ryu James's Avatar
12.24.2008, 11:45 PM
started to on one motor but any deeper might go through the can so i held off.
12.26.2008, 04:53 PM
Ryu James has chosen not to receive private messages or may not be allowed to receive private messages. Therefore you may not send your message to him/her.
pm prompt.........
Ryu James
Ryu James's Avatar
12.26.2008, 05:27 PM
pm prompt.........
i just checked everything and all private message recieval is enabled. i will pm you my cell # and just call me.
