Slash Question
plaviblue
plaviblue's Avatar
Slash Question - 01.14.2009, 11:24 PM
Is anyone using differential fluid? If so which weight works the best....just bashing.
With the brushless motor the slightest turn breaks the wheels loose.
FLM Extended Savage -Nue 1521 2d MMMv3 6cell
E-Maxx -Flm Parts stock motors (the wife's)
Slash -MM medusa 3300k 3cell 68 mph!
[B]Custom FLM Axial Crawler
Losi Rammunition 1/184600k
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
01.14.2009, 11:27 PM
Haha, I went right up to 100K in mine just for that reason! It's a bit too heavy though, as I have trouble turning sometimes. I'd say 50-70K would be better.
01.14.2009, 11:41 PM
The "proper" thickness fluid will leak out unless you mod the diff to seal it. By "proper", I mean the right thickness for normal driving.
plaviblue
plaviblue's Avatar
01.14.2009, 11:54 PM
I saw how to this on the overpowered slash thread.....thanks Brian!!!
plaviblue
plaviblue's Avatar
01.14.2009, 11:44 PM
I posted this just before I read through the slash thread....read before you speak
Thanks guys!!!
What's_nitro?
01.14.2009, 11:45 PM
Oh, I forgot to say I run Flat Irons on my Slash which are larger than stock. If your tires are stock size then I'd say 20-50K.
plaviblue
plaviblue's Avatar
01.14.2009, 11:52 PM
Do you have problems with the front tires rubbing the chassy?
plaviblue
plaviblue's Avatar
01.14.2009, 11:58 PM
What is the difference between the 50 and 60 series Medusa motors? I cant seem to find the info.
What's_nitro?
01.15.2009, 12:03 AM
My tires will rub a bit when I land a jump, but not when I turn.
The 60mm Medusa is longer, and so can produce more torque. The 50/60mm are good for 1/10 scale, or 1/8 buggy. The 70/80mm are good for fast 1/8 buggy, or MT (1/10 or 1/8)
