4s MM
pedeboi364
4s MM - 01.01.2009, 01:01 PM
Hey guys. Im planning on using an MM in my T-maxx and stampede, 4s and 2s configs. I think ill run an 8xl in the T-maxx on 4s, so i was wondering what mods ppl r doing to run 4s on their Mamba Max's. thnx!!
Check out my FS thread in the General Discussion!! Help me go lipoly!!!
01.01.2009, 01:14 PM
Just remove the red wire.
01.01.2009, 01:19 PM
On 4s, I would also run a ccbec...
pedeboi364
01.01.2009, 02:05 PM
i plan to run a ccbec, i 4got to mention. which red wire brianG??
01.01.2009, 02:06 PM
I would read my Emaxx FAQ and skip to the parts about BL and esc modification...
Brian's website explains all you need to know with regards to wiring- you need to take the redwire out of the rx lead to disable the built in BEC.
01.01.2009, 02:10 PM
The esc plug that plugs into your rx...remove the red wire, DON'T cut the wire, just remove the wire from the plug end, and you are good to go...don't forget to secure the wire in case you need it again
redshift
RC-Monster Square Tube
redshift's Avatar
You'll need a heatsink and/or forced cooling with an 8 turn, maybe consider a 9XL and gear higher. I have run my MM successfully for almost 6 months (in a 14.4 pound truck) with no mods other than disconnecting the internal bec, (I use a receiver pack) and adding a fan to the MM, just so I never get thermals.
pedeboi364
01.02.2009, 08:07 AM
hmm, so i should shoot for the or 10 xl?? i have the perfect setup idea regarding the red wire, but are the servo plugs/connectors easy to find. i wana shorten the MM lead, then be able to use 2 diff extensions (with n without red wires) to work differently between my T-maxx and pede. So im getting that i dont need to install a cap? what rx packs would u guys suggest for a T-maxx??? thnx!
01.02.2009, 08:46 AM
Personally I always add an extra cap - I had two blow up without caps - since adding caps all of mine have been fine... no other changes...
If it helps mike adds the extra cap to - it is only a $4 mod...
01.02.2009, 08:57 AM
the extensions work well.
i wouldn't use a rx pack, i'd use a bec.
i'd add a cap, here's one http://www.rc-monster.com/proddetail...=35vcap&cat=21
pedeboi364
01.02.2009, 09:48 AM
so take out the internal bec and use the ccbec??also, where do i add these caps??
01.02.2009, 09:57 AM
Close the esc as possible on the power lines...
Strip off a small amount of insulation about 1cm back from ESC on battery wires and solder in cap leads - again keep them as short as possible.
pedeboi364
01.02.2009, 10:03 AM
so i taps into the ESCs batt leads? should i take the cap off when using only 2s in my pede? do i really need a 10a bec? any others that r a bit cheaper? thnx
emaxxnitro
emaxxnitro's Avatar
01.02.2009, 11:15 AM
do you already have the esc? if you dont. i suggest just getting a mmm. you will end up spending just as much getting a mm ready for 4s when you could already have a mmm for the same price.
808E
pedeboi364
01.02.2009, 11:25 AM
$35 and a good amount of space would be wasted. it'd have fit in my pede, and i would be tempted to go 6s
