Speed Buggy
macr0w
macr0w's Avatar
Speed Buggy - 01.25.2009, 10:37 PM
I got to looking around and realized I almost had enough parts to get my old Prospec rolling again.
I've got my brushless MBX-6 and MBX-5T for offroad, so I decided to make a street machine out of it.
I had a Neu 1512/1.5/D/F laying around so I took the RCPD kit out of my truggy and ordered another MMM and one of Mikes motor mounts and battery trays to put back in the truggy.
I got these Losi street tires. Their a little short (only 3.75 inch) but I hope to get some good speed runs out of them. I also got a JR z9100t for steering, a Futaba receiver and a new body.
The only thing I'm waiting for is the MMM.
I'm going to try and gear it up for some speed runs.
I hope to break 70 mph or so. With a 16t pinion I should be in the ballpark at least.
Differential Ratio: 3.3333333333333335
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 17
Total Voltage: 16.8
Motor KV: 3300
Tire Diameter (inches): 4.5
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 2.71 : 1
Total Ratio: 9.01961 : 1
Tire Circumference (inches): 14.14 inches (359.08 mm)
Total Motor Speed: 55440 RPM
Vehicle Speed: 82.29 mph (132.18 km/h)
Effective KV Value: 3300
KT constant: 0.41 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
Other Ratio: 1
Total Voltage: 16.8
Motor KV: 3300
Tire Diameter (inches): 3.93
Motor coil Ω: 0
Tire Circumference (inches): 12.35 inches (313.6 mm)
Vehicle Speed: 71.86 mph (115.44 km/h)
