best screws for mounting a 1527 neu?
fatboyelroy
best screws for mounting a 1527 neu? - 03.21.2009, 04:30 AM
what are the best quality screws (flat head 3M) i can get to mount a 1527 neu?
George16
Supermaxx
George16's Avatar
03.21.2009, 05:24 AM
Any grade 12.9 or if you can do it, drill and tap it for 4mm.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
03.21.2009, 08:24 AM
use mikes front end bell protector - then you get four screws into the can...
03.21.2009, 09:46 AM
+1 on this, best 10 bucks you can spend. And if you happen to strip the threads you can just replace the 10 dollar cover, not the 350 dollar motor...
sikeston34m
sikeston34m's Avatar
03.21.2009, 11:12 PM
Is this the one?
http://www.rc-monster.com/proddetail...rontmotorcover
I guess the countersunk holes are for motor screws, then it mounts with the other threaded holes?
Is there one that catches all four screws on a Medusa? They have 2 on 25mm centers, but the other two are on 19mm centers.
03.21.2009, 11:21 PM
Is this the one?
Yep the medusa one fits all 4 threaded holes. I have one and it fits my 60mm v2 perfectly. A very good idea, as one of the threaded holes in my motor stripped out very easily. Use the drop down menu to select the medusa model.
RUSTY XL-5
RUSTY XL-5's Avatar
03.21.2009, 03:58 PM
+2 best $10 you can spend on your motor.
I will spank a nitro any day...guaranteed. :)
azjc
03.21.2009, 10:02 AM
I use the cover on all my Neu motors, it also makes sure a scew wont get into the motor and make contact with the windings
Bad Karma
03.21.2009, 03:20 PM
You might want to check your motor since I have a 1527 and it has M4 screws
fatboyelroy
03.21.2009, 03:34 PM
hmm? according to this schematic http://www.neumotors.com/Site/Motor_...xxF%20-web.png all 1500 series motors are tapped for M3 screws. how can i be sure of which one i have?
Bad Karma
03.21.2009, 04:51 PM
thread a 3mm screw in and if its loose in the threads try a 4mm, if it fits it's 4mm
fatboyelroy
03.21.2009, 09:36 PM
thanks
03.21.2009, 10:48 PM
m4 threads are an option. Both of my 1521 motors have the optional threads and 8mm shafts.
