my gear box and chassis fit...
jocktheglide
my gear box and chassis fit... - 01.06.2006, 06:29 AM
man my gear box had a tight fit the rod (shift fork guide) had a hard time going into the hole I had to modify the hole a bit. Same with the bulkless setup there are two pins that the hole were too small for, but I got them in. Also the gear box does not sit perfectly on the chassis there is a little hump in front, but other than that the whole setup is nice I will take pics when im done with everything.
