i don't run all that much. there are no tracks here, so all i use them here for are speed runs...no jumping or bashing, and this was only on 6S.
the more i think about it, i think what ultimately blew that dime sized hole in my 1.0case was a cartwheel i did with very little diff material inside the diff. it probably jarred the pins into the case and broke it that way. i had only run it about 10 times. i normally run with a center diff packed with play-dough as i like alot of acceleration. it had been due to be changed out.
I made sure to pack the nova case alot better this time. i can't see this problem if i'm using aluminum. if it does happen again i'll eliminate the planetaries all together and just jbweld the center diff together.
