7.5 Differential Kit, 6 Spyder Questions
RC Fan 4 Life
7.5 Differential Kit, 6 Spyder Questions - 01.23.2006, 12:47 PM
Hey guys i have the UE 6 spyder diffs and i think they will gear my truck lower so can someone do the math and tell me what spur and pinion gears i need to use, i would like to stay where i am with the power and speed i have.
currently using what Novak suggest for gearing on the HV spur 70 and 14 pinion.
I hope it's not hard to install. :)
Serum
Serum's Avatar
01.23.2006, 01:17 PM
Yeah, the normal e-maxx diffs are 37/13 and the 6spiders are 43/13. You need a larger pinion, or a smaller spur.
a 12T pinion or a 82 spur. Eversince the spurs are not available that size, you'r better of getting a 12T pinion.
nitrostarter
nitrostarter's Avatar
01.23.2006, 02:28 PM
Serum, you contradicted yourself there.
He's running 14/70 right now. I think a 16T pinion shold take care of it.
N. Rustler conversion
Serum
Serum's Avatar
01.23.2006, 02:34 PM
Yeah, my mind is playing tricks on me.. ;)
you need a larger pinion and a smaller spur..
RC Fan 4 Life
01.23.2006, 02:37 PM
Thanks! How do you guys figure that out anyway?
coolhandcountry
coolhandcountry's Avatar
01.23.2006, 08:53 PM
well you divide the pinion in to the spur and do the same for the diff gears and then multiple them by one another then take the new diff you are running and divide that into number you got by multiplying the old stuff.
70 divided by 14 give you a 5 to 1 ratio. with the diff ratio 37 / 13 give you 2.84 x 5 =14.23 divide that by the new diff you have 43 /13 =3.3
14.23 / 3.3 = 4.31 for you new spur gear ratio. Since you have 70 tooth spur just divide 70 by spur gear ratio 4.31 =16.21 so a 16 toothpinion
Peace!
Country
Help support the
Rc-Monster
Buy here
RC Fan 4 Life
01.29.2006, 12:48 PM
I'm not very good at math and that is confusing to me. Has anyone made a online calculator to figure this out? :)
Serum
Serum's Avatar
01.29.2006, 12:52 PM
here you go..
RC Fan 4 Life
01.29.2006, 03:11 PM
Originally Posted by Serum
here you go..
wow thanks but how do i input differant numbers?
