Crt.5 Brushless Motor !!!
Jason
Exclamation Crt.5 Brushless Motor !!! - 05.19.2009, 11:54 PM
I recently bought this and I plan running it on a feigao 8xl motor that I already own... and on 3s lipo... with a mamba max 1/10 esc.. should have no temps issues at all ? and good performances ? and does the diff & other drivetrain parts accept this sort of power without any trouble? I never owned a crt.5 before... ---->
Differential Ratio: 3.25
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 17
Total Voltage: 11.1
Motor KV: 2084
Tire Diameter (inches): 4.875
Tire Ballooning (inches): 0
Motor Current Draw: 83
Motor coil Ω: 0.0073
Spur/Pinion Ratio: 2.71 : 1
Total Ratio: 8.79412 : 1
Tire Circumference (inches): 15.32 inches (389.01 mm)
Total Motor Speed: 21869.7 RPM
Vehicle Speed: 36.07 mph (57.94 km/h)
Effective KV Value: 1970.24
KT constant: 0.65 oz-in/A
Motor Torque: 0.28 ft-lbs
Final Torque: 2.47 ft-lbs
Final Power: 921.3 watts (1.2 HP)
