I have just do my finish result of my kyosho, now it is how I want...... It run with neu 1515 3d on 6s 5000mha, Can I run 30min?. I want that it run very cool, because in Spain the temps in summer are high, are about 110f or higher.
Hello I have just run the buggy with 100ºf air temp, and the motor run about 149ºf the higest was 167ºf with final top speed of 45.16 mph on 22.2v it is too speed???
For reduce weight and temperature because my lipos weight is 1.76lbs, And now I want to run it lipos http://www.hobbycity.com/hobbycity/s...idproduct=9268
Are enough? with less weight I will have less temp?
i would just gear down a tooth or two on the pinion gear. that should lower your motor temp a little.
OK but I want to run only one lipo 6s 2630mha 30c, is enough?
That depends on how long your run time needs to be....The set up will work
I have just buy 4 lipos trunigy 3s 4000mha 20c for run on series....And a MicroPower V3 E-Logger but I don't know how to put it in my car, because my car have wires for conect the batteries in serie........
