Originally Posted by Cmendastrtduk
Hello I'm new to the tc world and need some help.... I have a traxxas slayer conversion. To electric....the thing flies and handles both on the ground and In the air...however I have had to rebuil the transmission like four times.....I already turnned the punch control down to 50%. And it still rips through the transmission gears..... So here is my ??? Do u think a e maxx trans will bolt in to the slayer.... And even better does any one make the slayer trans gears in hardened steel???? If so where can I get them..... Thanks
Traxxas e- slayer mamba monster 6cell 2700kv
You need to turn the punch control UP to reduce the stress on the tranny gears.
Since the Slayer is just a truncated revo, you can happily bolt an emaxx 3905 tranny into it- you just have to make a little mounting adaptor due to the different screw pattern/ width:
Very straight forward- make a cardboard template to get the holes in the right locations, and the shape correct.
FYI though:
1. Posting the same question in several places is called spamming.
2. The Summit has the crappy locking diffs that strip if you try shifting whilst on the move.
3. Loving the sun, though Im working inside (retail sector, yay)- monday and tuesday off though...
