Chargers...
Slowkrawl
High-Voltage Fetish
Slowkrawl's Avatar
Chargers... - 07.07.2009, 12:37 PM
Well my hobbico accu cycle just doesn't charge fast enough for my lipos(max of 2A...) so I have been looking into a new one. I have been looking at the hyperion chargers a bit, but to be honest they confuse the hell out of me. I can get away with a lipo specific charger, because I am going to keep the hobbico for the nimh's. My current lipo's are 5400mah, so I could charge them at around 5A, but I would like some headroom. Maybe a charger that does 7-8amps? Thanks for any input guys,
-Matt
07.07.2009, 12:41 PM
Its the Volts X Amps = Power (W) that you have to watch for...
Hyperion 610 / 615 / 720i etc all rock
07.07.2009, 12:50 PM
Chris is right, if you want to charge a 6s lipo at 8amps you need a charger capable of 200watts or more.
There are alot of chargers on the market, usually the sub 100 dollar models are 50-70watt max output. Ok if you are charging 2s-3s 5000mah packs as you can get 5amps out of them at that voltage. If you want to charge 55-6s packs quickly you need a good charger.
I have seen the 610i hyperions sell used on rcgroups for around 120... I almost bought one at that price, but I already have 2...
07.07.2009, 01:11 PM
I've got a 1210i I picked up new, and I love it. I believe holmeshobbies (johnrobholmes on here) is selling one used for $110.
07.07.2009, 01:12 PM
allerc has the non balance 1210 for 85
07.07.2009, 01:13 PM
I paid double that... Dammit!
Slowkrawl
High-Voltage Fetish
Slowkrawl's Avatar
07.07.2009, 02:10 PM
I will check that out, because I like using my blinky balancer. *flame suit on* my packs usually stay in the truck while they charge so it's just easier to use a blinky. So I would need a power supply too then?
07.07.2009, 02:17 PM
roger - out
Slowkrawl
High-Voltage Fetish
Slowkrawl's Avatar
07.07.2009, 03:25 PM
Any big different between the 1210i and the other chargers? As stated I will be using blinky balancers anyways. Soo my last question, I will need the power supply? What exactly am I looking for? Linc told me a computer power supply will work, what specs do I need? As you can tell I am a bit of a noob to chargers.
07.07.2009, 03:56 PM
Roger = Yes you will need a PSU.
You want something with a good PC supply 20amp 12v single rail... modding a PC power supply is pretty easy - i did it :)
$40
http://www.newegg.com/Product/Produc...82E16817159026
NoControl
NoControl's Avatar
07.07.2009, 04:03 PM
I still think a decent sm psu rated at 144w 20-30v ~7a works great, its what I use and I can run 2 3s packs on a 610i duo, with next to no sag costs like 40$ shipped on ebay and just need a for + nad -.
Hers one for folks who need lots o powa http://cgi.ebay.com/Mean-Well-SE-600...3A3%7C294%3A50
wow theres a lot more power supplies on there now that are 24v 3a-25A just do an ebay searh for power supplies and look for ones that like the one above, especially if you get a hyperion charger I think most of them can run from 12v-28v, I run mine at 26.6V and i have no problems.
E-revo MMM 2200 6s zippy 50MPH of pure fun and parts destroying powa!
Futaba 3pk more controller then anyone person needs
TC5 top speed drifter 21mph on crappacks and 40 on calc
Byte
07.07.2009, 04:04 PM
I got some questions about that charger:
- Is it able to work on 12V and 220V?
- Does it have a charge limit? (mAh) Because my current charger can only charge LiPo's which have 5000mAh or less, that sucks...
Thanks
07.07.2009, 04:17 PM
The hyperion models that have a built in AC/DC converter are limited to 50w i.e. slow charging for a 4s 5k pack...
The DC ones are 180-250w+ depending on model
e-rev project
07.07.2009, 07:45 PM
for a power supply i think this is a kick ass deal for 60 buck free ship to store . I have the 13.something volt 25 amp and paid 80 used.. damn!!! this one is 25 amp as well
07.07.2009, 08:43 PM
Here ya guys go, I use the larger of these 2, great guy, and great PS.
http://www.rcgroups.com/forums/showthread.php?t=1051873
