I finally got my gmaxx running this week and got somewhere around 10 runs on it. The 8xl+9920 was doing great nothing was getting over 130* good power on anything from 12-16 cells. Until today. I was playing around in the street with it normally the road rages spin bad on my street but for some reason they hooked one time and it flipped over backwards pretty hard and tons of pink smoke started poring out. When I got to it one of the batteries had been thrown out and broken a solder joint on a battery bar. The cells are glued together so it was still making contact. Any ideals on why it died? Every joint was shrink wrapped with nothing exposed to short the esc was zip tied on a 1/2" piece of foam to protect the bottom.
Did your batteries short out to the chassis or something?
I guess it’s possible they did while coming loose but when I got to the truck it was on its roof and the pack that was loose was sitting in the roof not shorting on anything. The other pack hadn’t moved. There are no burn marks on the chassis to indicate that they did tho.
Yeah, smoke from burnt components is usually a normal grayish color. Pink smoke sounds like there's some other chemical was present. Are you sure it was pink and not some trick of sunlight or something?
Did you look at my pics? The esc is what was smoking only the esc is damaged. The color of the smoke doesn’t matter I just mentioned it because it was kinda cool to see pink smoke poring from my emaxx.
How old is your 9920? On the one I have all the wires and capacitors terminate on the same end and in your pictures I can't see any capacitors or your negative lead. On that topic how do your capacitor look? Are they bulging out the ends at all?
Yeah, I saw the pics and it's obvious the ESC burnt. The color thing was weird that's all. I hate the unexplained. :)
I blew up a tekin 420g2 once, lots of green smoke came out. I guess its just something in the controller that burns a funny colour (maybe the heatshrink?)
