New firmware 3.18 for MMM
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
New firmware 3.18 for MMM - 10.11.2009, 11:39 AM
http://www.castlecreations.com/downl...-download.html
No brain, no headaches.
Nard Cox
n00b
10.11.2009, 12:01 PM
Did you already try it ?
Castle Link:
  • Bug preventing some nationalities from being able to run Castle Link correctly has been fixed
  • No longer have to 'Run as Administrator' to store your default motor-pole / gear ratio setup
Castle Link Graph Viewer:
  • Added ability to display temperature in degrees C or degrees F
  • Added ability display actual head-speed or prop-speed by entering the gear ratio
  • Removed menu items to select individual data-curves, instead simply click on the label below the graph
  • Added a 'How To' help menu option
  • No longer have to 'Run as Administrator' to change your motor-pole / gear ratio or temperature setup
Source
mistercrash
Guelph, Canada, eh!
10.11.2009, 12:03 PM
I installed it on my computer and updated my ESC but I haven't tried it yet. I'm recharging a couple set of batteries right now.
10.11.2009, 12:02 PM
Ooh cool. Going to update now.
needforspeed
needforspeed's Avatar
10.11.2009, 12:07 PM
Thanks,I got it 2 days ago.I should have posted it then. Or maybe they could send a automatic e-mail to people in there database to let us all know.But hey Im not complaining
SunnyHouTX
SunnyHouTX's Avatar
10.11.2009, 12:36 PM
The change I like the most is that you can now program the Mamba Max via receiver cable like the Sidewinder. So now I don't have to dig my ESCs out of my drag cars every time I need to change the tune. Very convenient for me. Thanks Castle!
mistercrash
Guelph, Canada, eh!
10.11.2009, 03:39 PM
Here's my full review on the new software:
I tried it and it works.
Hey that's as technical as I can get with the knowledge I have.
10.11.2009, 03:48 PM
wow..
Mamba Max:
Added ability to program Mamba Max via the receiver cable with a Castle-Link device (instead of being required to plug the unit into a USB port)
BUT IS THE DRAG BREAK FIXED?
phildogg
phildogg's Avatar
10.11.2009, 04:04 PM
wow..
Mamba Max:
I like that!!
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
Semi Pro
Semi Pro's Avatar
10.11.2009, 04:48 PM
wow..
Mamba Max:
best update so far
brushlessboy16
brushlessboy16's Avatar
New software runs 4s fine :)
Freezebyte
10.11.2009, 07:00 PM
Darn, no ability to change fan temp adjustment. And what and where is this temperature thing? And whats wrong with the drag brake? I've never had an issue with it
10.11.2009, 07:32 PM
Drag brake sucks for rock crawlers - Brushed thing...
Freezebyte
10.11.2009, 10:10 PM
You can take turn it off completely
10.11.2009, 10:26 PM
Eh don't follow - On a crawler you need and run with 100% drag break...
