Question about 5S. -
01.29.2009, 07:51 PM
Hey guy's, I had someone say to me that it's possible to use a 2S & 3S pack to make up 5S.
Now, I didn't think it was possible due to the different amp ratings of each pack.
Am I right thinking this way or is it possible?
Losi SCTE SC4 Pro 4000kv, Tekin RX8, 2S
MP7.5 Kanai III Tekno Neu 1515/2.5D 1700kv MM 4S
LST 2 Carbon CC 1717 1Y 1580kv MM 6S
Futaba 3PKS Spektrum Pro
01.29.2009, 08:45 PM
Well, if the amp-hour is the same on both packs, they have been used the same number of time, have seen the same type of usage, and are about the same age, then yes, just put them in series.
"Out of spec" enthusiast
01.29.2009, 08:59 PM
I bet if you are sure one pack has less mah AND a smaller amp rating than the other, you can put an external lvc just on just that pack and not have to worry about the stronger pack going below the minimum voltage.
01.30.2009, 12:25 AM
Problem with this is the setup will have to draw way lower than the smaller pack can handle. If it is even close to the smaller pack's cont rating that pack will most likely puff from over discharge. Just buy the right thing. 5s is a good voltage to run stuff at, but if you have to run 2 packs go with 6s.
01.29.2009, 09:01 PM
Too much hassle.
Are you guy's aware of anyone that makes hardcase 5S packs?
01.29.2009, 09:05 PM
Team Losi has a 25c 4000 mAh 5s hardcase pack. Too expensive imo seeing that my Neuenergy 25c 3900 mAh was less than half the price.
Monster Bottle Opener
01.30.2009, 12:18 AM
Chargery makes a 25 and a 30c 4000mah.
I used a "bottom" line.
01.31.2009, 12:31 AM
Originally Posted by hoovhartid
I like these, but, where on earth do I get them from?
Well, I emailed Chargery & received a response on prices.
Here they are...........
The unit price is as below, it is based on FOB Shenzhen.
CPL4000-5S, 125USD
CPL5000-3S2P, 95USD
CPL5000-4S2P,125USD
CPS3300-3S, 59USD
CPS4000-5S, 115USD
PS5200-3S2P, 89USD
PS5200-4S2P, 119USD
http://www.chargery.com/8carbattery.asp
01.31.2009, 06:48 PM
Ive got over 3 year old TrueRc 2s and 3s 8000mha packs Ive been running in series for a 5s setup in my revo. 3 years and still kicking. I charge them and balance them in series too though so they in all reality have been treated the same as a single 5s pack. As long as both packs are the same cells and always run together there should be any issues at all. Its very common practice to do this.
to make it...
or break it...
Silent...But Deadly
01.31.2009, 07:01 PM
I've run my converted revo on a 2S and 3S 4300mAh 20/30C zippy K packs in series for 5S with a series connector. The packs are a few months apart in age so the cells aren't matched. But they drain equally and I ballance charge them every use.
Supermaxx
01.30.2009, 12:53 AM
I had been running a 5s setup using a 2S 5000mah 25c/50c and 3S 5000mah 25c/50c. Both are Neuenergy batteries and same age. So far no problems at all.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
01.30.2009, 05:58 AM
Same here, no problems
RC-Monster Spudgunner
01.30.2009, 09:07 AM
This guy runs a 2s and 3s in his muggy. In the vid he explains his setup.
http://www.youtube.com/watch?v=NrNgAHHHNZs
He is a mod over at the toyz...
01.30.2009, 10:28 PM
EMuggy is a member here too, used to be a mod over at BYT- Squirrel of Death. Long time ago...
01.22.2010, 09:53 PM
hey i have 2 muggys
im converting 1 to electric i got the mamba monster 2200
i have a buddy that has a traxxas summit with lipos and he said he would sell me the lipos .
does anyone know if and how they would do with my e-muggy set up they r 5000 mah 3s 11.1v and 5000mah 2s 7.4v
