Snow cover for mmm!!!
speedy
Snow cover for mmm!!! - 11.07.2009, 12:24 PM
Hi !
I just thought of a way to protect my mmm esc from snow and grime ....
I put a outwearbag made for 1/5 airfilters over the intire esc ! This protects it from snow and water spashes from snowbashing
11.07.2009, 12:27 PM
not a bad idea!
cover
3905er
cover - 11.07.2009, 06:12 PM
I need pics or a part number thanks.
Byte
11.07.2009, 06:22 PM
I would also like a pic of it :)
speedy
11.07.2009, 06:55 PM
HI !
I don't have any pic's of mine but here is a link to the outwear filters http://www.davesmotors.com/s.nl/c.88...t.A/id.4384/.f
To fit it to the mmm-esc i just bent the wire's down and let the elastic opening slip under the mountingplate for my esc ! the filter is easy to remove and i gotthe on/off switch covered by the filter to ! i 'can operate the swich inside the filter ! no need to remove the filter !
johnelway
11.30.2009, 11:26 AM
Do you have some overheat problem?
can you take some pics please?
speedy
11.30.2009, 02:15 PM
I disided not to use this cover because i think my esc might overheat ! So i coated the circutboard with plastidip instead and that seems to work great !
pmv_rc
03.03.2010, 08:35 PM
what about some sort of dust cover(if planning to run in dusty track conditions)??...or does a mmm esc not need protection from dust??
sorry guys,im a brushless newb
riverat1540
riverat1540's Avatar
03.04.2010, 03:57 AM
speedy i think u had a good thing going, the outerwear woud have been fine as long as it keeps the snow and water out of the esc, plastic dip is most likely worse at dissipating heat then the mesh cover. ive heard of people running their truggys with a shower cap over the whole frame worked great and no overheating problems, but after all it is cold ouside ill buy it off you for 10 shipped
pm me if u dont want it!
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
03.04.2010, 04:29 PM
Dust isnt really an issue- you can blow that out of the esc with a compressor easily enough, or use a thin layer of foam sponge between the erevo MMM hold-down and the top of the esc- stops the fan sucking in dust but still allows the esc to breath through the exhaust vents in the side.
Cartwheels
03.04.2010, 11:49 PM
Have you guys seen this corrosionX way to waterproof. I think it has been posted before.
I wonder though if corrosinX would collect dust in the summer time?
http://www.youtube.com/watch?v=6jpSW50cobs
riverat1540
03.05.2010, 05:10 PM
Now that looks like it is worth trying, never know when a puddle is going to come out of nowhere!, or a creek!
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
V0RT3X
Muggy love
V0RT3X's Avatar
03.05.2010, 01:53 PM
It dries off and nothing sticks to it. I got some on my MMM case when I coated the PCB and the stickers don't hold anymore. Also doesn't overheat. :)
