Cheat
Cheat - 04.22.2010, 03:24 PM
I guess i should know but is cheat available on the MMM and orginal MM - If not why not?
Just wondering as at speed the mmp isn't using the sensors...
Cheers
04.22.2010, 03:30 PM
IIRC, Cheat mode is a direct function of sensored-only operation. So, even in the MMPro, you have to be in sensored-only mode to use cheat (not smart sense).
Semi Pro
Semi Pro's Avatar
04.22.2010, 03:32 PM
can you explain cheat mode? is it just dynamic timing advance or something else?
nitrostarter
nitrostarter's Avatar
+1, as to that is how I understood how the system works.
N. Rustler conversion
04.22.2010, 03:35 PM
Honestly, I don't know. I've never played with sensored operation during testing and since. Sorry.
Probably gonna have to wait for a CC rep for that level of questioning.
04.22.2010, 03:52 PM
Its just dynamic timing advance as I see it but not sure why this still isn't possible under sensorless operation to...
Semi Pro
Semi Pro's Avatar
04.22.2010, 04:10 PM
dynamic timing advance doesn't work on the rx8 without the sensor plugged in, i think sensorless is always dynamic up to your set max
i agree i would love to here what Patrick or one of the other engineers has to say about it
whitrzac
Can't catch this...
whitrzac's Avatar
04.22.2010, 08:02 PM
the RX8 does not have the same type of timing advance as the RS/MMp, hence the reason I sold my RX8
Pdelcast
Pdelcast's Avatar
04.23.2010, 12:41 PM
Dynamic timing does happen sensorless -- but above about 30 degrees of electrical advance, there just isn't enough back-EMF information to allow more timing.
With sensors, you can advance the timing more aggressively than you can sensorless. It's MUCH MUCH harder on the motor and ESC, but in stock class racing, can make all the difference.
I wouldn't try it on a high quality motor, just the junk they run in ROAR stock.
Patrick del Castillo
President, Principle Engineer
snellemin
2 KiloWatt RACER
snellemin's Avatar
04.23.2010, 03:08 PM
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
FastXR
04.23.2010, 04:58 PM
Well said Patrick. You must be an a particularily nasty mood today.
Pdelcast
Pdelcast's Avatar
04.24.2010, 12:36 AM
LOL, what I meant to say was:
High quality motors don't need a lot of timing to perform well.
Semi Pro
Semi Pro's Avatar
04.24.2010, 02:02 AM
you know you could prove to the world how good CC is and make us some roar aproved motors and change up the game untill everyone else catches up again.
then we wouldnt have to race with red and bash with green
quick thred jack while i am here
can the MM handle 144300rpm or are the shudders comeing from the poor motor
sadly the motor is running pretty cool for being that far over voltage
FastXR
04.24.2010, 09:04 AM
No I like it better the first way
simplechamp
simplechamp's Avatar
04.22.2010, 07:32 PM
It's my understanding that the CHEAT mode enables timing advance at a certain RPM, or range of RPMs, and you need the sensor to measure these RPMs accurately.
