Calculating runtimes
Nick
COOKIES!
Nick's Avatar
Calculating runtimes - 04.08.2006, 03:50 PM
Is there a way of calculating the run times by voltage/capacity of batteries and RPM of the motor with weight?
I'm sure nearly everything effects it but wondering if there is any rough calculation to knowing.
~ Nick.
maxxdude1234
maxxdude1234's Avatar
04.08.2006, 04:20 PM
There are soooo many factors that affect runtime, that to be honest, a good guess would be as accurate as any calculation. The main thing that affects runtime is driving style, and theres no real way of integrating this into a calculation, seeing as everyone drives in a different style.
Serum
Serum's Avatar
04.08.2006, 04:22 PM
Amen maxxdude..
just do a testrun, it saves you a few days of calculating.
maxxdude1234
04.08.2006, 04:26 PM
Also, once you've got a rough idea of the runtime you get with your system, if you change to different capacity batteries you should be able to get a fairly accurate idea of runtimes. ie, If you got 15 minutes with 3000mah packs, you should get 30 minutes with 6000mah packs.
Superemaxx89
04.08.2006, 04:38 PM
how much runtime/speed do you think i'll get?:
10xl
22.2 volts
8000mah
12lb truck
15020 warrior
any guess is fine.
coolhandcountry
coolhandcountry's Avatar
04.09.2006, 12:09 PM
10xl
22.2 volts
8000mah
12lb truck
15020 warrior
any guess is fine.
I would say about an hour or more. I got 25-30 min on a 9xl with gp 3700.
Peace!
Country
Help support the
Rc-Monster
Buy here
maxxdude1234
04.08.2006, 04:53 PM
I would guess someone around 45-60minutes. Very long in other words.
Nick
COOKIES!
Nick's Avatar
04.08.2006, 05:08 PM
The idea was to know before I BUY new batteries. :P
~ Nick.
maxxdude1234
04.08.2006, 05:13 PM
I'm sure if you tell us your set-up we could give a rough estimate of runtime.
Sylvester
Sylvester's Avatar
04.09.2006, 12:52 PM
How about somthing like this:
10L
14.8V
6000mah
9.5lb truck
9920
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
maxxdude1234
04.09.2006, 12:55 PM
About 40 minutes I would guess
blackhawk444
04.09.2006, 01:18 PM
How about this...
540C-9L
Genesis Truck esc
12 Matched GP3300 cells
1/8th Jammin X1-CR buggy
Thanks alot!
squeeforever
squeeforever's Avatar
04.09.2006, 01:21 PM
i would guess around 12-15 minutes depending on how you drive it.
blackhawk444
04.09.2006, 01:53 PM
Thanks, I will probably upgrade to IB4200's. Should boost the runtime up to about 17-19 minutes? That would be awesome...Thanks again.
squeeforever
04.09.2006, 06:02 PM
yea, somewhere around there. 15 minutes should be pretty easy.
