I want some new shocks.
Bmr4life
I want some new shocks. - 09.17.2010, 01:45 PM
My DB17 is roughly 14-16lbs depending on which batteries and tires I'm running. I want to upgrade the stock shocks.
I know people have done the LST shock conversion, but are there any other options?
Thanks
88gtanotchback
09.17.2010, 05:01 PM
you could use baja shocks. i didnt like them because i wasnt heavy enough but they may be the ticket for ya
Last edited by BrianG; 09.17.2010 at 05:20 PM. Reason: Formatted to fit on screen without scrolling...
thzero
09.17.2010, 10:53 PM
Are those the FLM Losi standoffs?
Nard Cox
n00b
09.17.2010, 05:33 PM
X2 on the Baja shocks. Was planning to try them on my Flux but it was way to light.
You could always upgrade to the alu BB shocks, or run 2 shocks on each corner though I'm not a big fan of that.
Bmr4life
09.17.2010, 07:32 PM
I doubt my truck is heavy enough for baja shocks. A baja weighs over 20 lbs without fuel.
I also don't like the double shock idea. What are the alu BB shocks you speak of?
_dV
09.17.2010, 08:08 PM
HPI Alu big bore shocks
If you want to upgrade the shocks to handle the extra weight then try stiffer springs and or heavier oil in the stock shocks first and see if you like the results. They are a fairly decent shock.
If you can add some sort of shock tower support that would help as well as they bend a lot.
Bmr4life
09.17.2010, 08:19 PM
Are these the spring people are talking about when they say White Hellfire springs? Link
I like that shock tower bracing, real neat.
Are the stock shock towers supposed to be slanted at all or straight up and down? Mine are slanted but they were like that when I got the truck.
_dV
09.17.2010, 08:28 PM
Yes those are the springs.
The shock towers will permanently deform over time. Left deformed, right new.
The diff casing angle on the front means the tower would lean in toward the center of the truck a bit but the rear should be close to straight up and down if it isn't bent.
thzero
09.17.2010, 10:52 PM
Yes. The front shock tower slants back due to the kick up at the front for caster. The rear shock tower does slightly lean forward.
Those are the springs. The Flux shocks (and the BB versions) use the Hellfire springs. I'm running white on my 17lb 5T, however I am thinking about going to the yellows.
Here's a list of all the springs:
#86549 SHOCK SPRING 18x80x1.5mm 12.5 COILS (BLUE 71gF/mm)
#86550 SHOCK SPRING 18x80x1.5mm 10.5 COILS (SILV 89gF/mm)
#86551 SHOCK SPRING 18x80x1.8mm 14.5 COILS (PINK 134gF/mm) (Flux kit part)
#86553 SHOCK SPRING 18x80x1.8mm 12.5 COILS (WHIT 159gF/mm)
#86554 SHOCK SPRING 18x80x1.8mm 11.5 COILS (YEL 177gF/mm)
#86555 SHOCK SPRING 18x80x1.8mm 10.5 COILS (RED 196gF/mm)
Bmr4life
09.17.2010, 11:50 PM
Thanks a bunch for this spring info. I'll give the stock shocks another chance with some white shocks and 45w oil.
Bmr4life
09.17.2010, 09:14 PM
Alright, guess its time for some new shock towers.
Muggydude
09.18.2010, 12:28 PM
I'm running that on my flux and it does a pretty good job (has the tube and an extra spacer on them)
R.I.P. Muggy, Rustler, VXL Slash
EFlite Blade MSR Heli (Slightly modded)
1/16 BL E-revo
8-t 2.0, OS Vspec with Speed conrod
Carbon Fiber Revo 3.3 Coversion Madness!
Bmr4life
09.18.2010, 02:05 PM
So the purpose of the tube and spacer are to make the truck ride lower?
Muggydude
09.18.2010, 07:58 PM
No! to make it ride higher and be stiffer!
1/16 BL E-revo
Bmr4life
09.18.2010, 08:00 PM
Crap, now I'm feeling stupid. I get the be stiffer, but how does this make it ride higher?
Is this change noted in the manual or any pictures anywhere?
