Need to countersink holes in CF, which bit do I need?
simplechamp
simplechamp's Avatar
Need to countersink holes in CF, which bit do I need? - 01.09.2011, 05:27 PM
I need to drill 4 (or possibly 8) holes in the bottom of a CF chassis for mounting lipo trays. The screws are M3, and I already have a 3mm pure carbide bit for drilling the holes, but I also need a bit to countersink the holes.
Can anyone suggest the bit I should use? I would like to find something cheap, even if that means tossing it out after I'm done. I know the CF dulls tools fast.
PBO
RC-Unobtainium
PBO's Avatar
01.09.2011, 05:33 PM
Just a regular CSK bit will work fine for 4 holes
Enhanced Rustler 1515 1.5 MMM
Losi 8ight-T
simplechamp
01.09.2011, 05:43 PM
Do I need a certain angle or anything? Or are metric flatheads a standard angle on the head?
EDIT: Wikipedia says "Countersink cutters are manufactured with six common angles, which are 60°, 82°, 90°, 100°, 110°, or 120°, with the two most common of those being 82° and 90°. Countersunk-head screws that follow the Unified Thread Standard very often have an 82° angle, and screws that follow the ISO standard very often have a 90° angle."
So which do I need?
PBO
RC-Unobtainium
PBO's Avatar
01.09.2011, 06:45 PM
So which do I need?
Well, do you now the CSK angle of the screw head? that would be the answer
I wouldn't worry too much about pressure angles unless the tensile load is extreme. If you want to be certain, bed the screws in with epoxy - this will allow mirrored pressure angles
Losi 8ight-T
mjderstine
mjderstine's Avatar
01.09.2011, 07:23 PM
the most common at 82. so unless you got goofy screws you should be fine!
simplechamp
01.09.2011, 07:51 PM
Just using standard M3x0.5 flatheads. I didn't know if they are Unified Thread Standard or ISO like the Wikipedia entry mentioned. Just did a bit more searching and looks like they are ISO so I'm going to use a 90° countersink
brushlessboy16
brushlessboy16's Avatar
Metrics use 90 degree IIRC
pb4ugo
01.09.2011, 10:00 PM
BB16 is right--metrics are 90 and standards are 82. I've had difficulty finding 90 deg countersinks locally, so the best setup I've found is a 90 deg carbide router bit. If only four, you could get away with HSS, but the carbide isn't too much more in router bits.
brushlessboy16
01.09.2011, 10:52 PM
Mcmaster carr
P/n 3013A43
mjderstine
mjderstine's Avatar
01.10.2011, 11:42 PM
oh, my bad, i have been using 82 on metrics for a while now without an issue... just torque em down :) :)
