HB D8 RC-Monster motor mount
TRD4Life
TRD4Life's Avatar
HB D8 RC-Monster motor mount - 01.07.2011, 12:05 AM
just purchased the D8 conversion kit....fit and finish is amazing!!!
the newer style motor mount is giving me some grief.......i installed the silver pivot bushing on the bottom pivot mount and installed the black pivot bushing in the top to tighten the motor down
is the top screw only suppose to be tightened down?
i am new to this kind of mount, so please bare with me
thanks
brushlessboy16
brushlessboy16's Avatar
01.07.2011, 01:53 AM
Black bushing goes on the bottom, machined fit into the bottom hole,
Silver aluminum piece is a spacer that goes on the upper radius'ed slot.
both screws should be cranked down
TRD4Life
TRD4Life's Avatar
01.07.2011, 09:18 AM
is the bottom bushing suppose to slid all the way through the hole?
i figured there would some sort of stop machined in
brushlessboy16
01.07.2011, 09:28 AM
no, it doesnt need it, the mount is just as strong as the older style mount as long as your upper screw stays tight.
TRD4Life
TRD4Life's Avatar
01.07.2011, 03:57 PM
i finally got it figured out
i had the bushings in the wrong spot.....switched them around and everything works fine now
thanks
