Hi everybody. I'm thinking about a quality charger. I know both are good, but speaking intelligence wise,
which one has a more precise balancer and is gentler with lipos?
I'm ready to hear your opinion and experience
I personally have heard people are getting tighter cell voltage tolerances with Hyperion.
Don't know about lipo cycle life though...
I switched to i-chargers a couple years ago, at the time they had the highest watt output per dollar. They are great chargers. The higher end (and newer) models have closer balancing tolerance.
Bottom line; always check the watts of the chargers you are comparing... a lot of cells and a lot of amps do no good if the watts are low.
I use Hyperion chargers myself, along with Hyperion Lipos. They are fairly priced with high quality you can count on. I am sure there are other nice chargers as well, but I have no reason to switch(and I am a reseller for Hyperion already).
