my Quark125b esc
andywpj
my Quark125b esc - 12.10.2006, 07:12 AM
i am mod my quark 125 esc , i use 3mm copper pad stick fet
very great for temperature and not temp issue.
i try noload run 30 min use moto 2400kv 14.8v , the moto come to 100c temp,
esc come to 52c.
some pic:
ID:	2046   Click image for larger version
ID:	2047   Click image for larger version
Serum
Serum's Avatar
12.10.2006, 08:06 AM
NICE done!
A controller normally doesn't get hot when the motor is unloaded though.
Serum
Serum's Avatar
12.10.2006, 08:07 AM
Is that castlecreations wire you used?! :p
coolhandcountry
coolhandcountry's Avatar
12.10.2006, 10:03 AM
Could it be the motor has such a sucky effiecency that it makes to much
wattage into heat?
Peace!
Country
Help support the
Rc-Monster
Buy here
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
12.10.2006, 01:41 PM
NICE! You made me want to try it again!! :019:
Yah, i tried the same thing with running no load... the motor as pathetic efficiency no load, it gets warm instantly! The controller got a little warm. You really shouln't do it though, you could rev the motor past it's safety limit...
zeropointbug
Z-Pinch racer
12.10.2006, 01:43 PM
Oh, and yes! I love the wire you used there! What brand is it, and/or where did you get it.
andywpj
12.10.2006, 02:18 PM
yes i change motor and power wire to castle creations 12AWG wire .
i think is mod no heat problem, if need just add outside heatsink.
Serum
Serum's Avatar
12.10.2006, 03:48 PM
Yeah, you did a great job, no doubt.
Reving a motor on no load is bad... you would not be the first who broke a magnet on his feigao! if it brakes, it can result in a burned down speedo.
