Originally Posted by GorillaMaxx360
Does anyone who has the carbon fiber battery straps (Made by GorillaMaxx) know the distance(amount of space) between the bottom side of the strap and the chassis. Also do you think the team orion 4800 will fit snugly onto these battery straps with no movement(without using the cell adapter just the flat side). And If it wont fit is the gap small enough to put a piece of foam (thicker than stock foam that comes with the g-maxx pads) on the bottom of the graphite strap to make a snug fit. Thanks for your replies.
Really guys what do you think will it work it would seem like it would because with the right amount of foam and adjustment it should fit snug without straining the carbon fiber braces because it will sit flush with the battery because it is flat. (
Serum if it is flush with the battery the braces are not needed and it seems it wound be the top of the graphite strap against the flat battery so there does not seem to be strained (flat surface pressing against flat surface allowing the pressure to hold the batteries in place) am i right or it just totally wont work if so thats cool just tell me. Thanks for your opinions)
