Cut off on 37V lipo -
01.04.2007, 10:24 AM
i'm going to bulid a brushless fg, i'm going to run with 37v lipo (18.5Vx2)
But is there a way to get cut of on this setup
At maxamps i can find cut of for 5s lipo, but can i use to of them? One to each battery, is so how do i wire them?
Sorry the bad english i'm from Norway
01.04.2007, 10:34 AM
01.04.2007, 10:40 AM
thanks that wil work
01.04.2007, 10:43 AM
yea and its only $20
COOKIES!
01.04.2007, 11:42 AM
I have that one, it kept locking in to full throttle and shooting off, had to take it off.
01.04.2007, 11:56 AM
Ouch! That could be bad if you're not expecting it! If you pull the label off, is there a little surface mount potentiometer on there? I'm thinking you can set the throttle position with this, kinda like you do with an external failsafe. Just a thought.
COOKIES!
01.04.2007, 12:10 PM
It was bad because you didn't know when it was going to do it, so I had to go really slow, lol.
Not seen anything under the label but it definatly feels like a malfunction/interference rather than programming.
01.04.2007, 01:01 PM
Yeah, i contacted dimension engineering about it a few months back. They told me it would be fine to use it on a truck.
BMW M Power!
01.04.2007, 03:01 PM
What??? Shoot off? Thats horrible...not only bangs the truck up, but fries that pack too!
I know I was stating the obvious...but its fun sometimes lol...
01.04.2007, 03:44 PM
I'd like to get a hold of one of those to see if it could be easily modded (any donors? :)). Since it goes into full forward when triggered, it simply puts out 2ms signal pulses to the ESC telling to go full bore. If an adjustment was added to reduce this to 1.5ms, it would go to neutral instead. You could also set it to put out 1ms pulses instead so it goes full brake instead too...
01.04.2007, 06:09 PM
or full reverse :002: depending on how you have the ESC setup
to make it...
or break it...
Silent...But Deadly
01.04.2007, 07:14 PM
True. I guess my point is that it would be nice if it was adjustable to whatever application...
RC-Monster G-Maxx
01.04.2007, 07:17 PM
Per Serum's suggestion, I got one of these and run it on my 5s Maxx. It works great, ONLY if you don't have reverse programmed.
COOKIES!
01.04.2007, 08:34 PM
How do you mean reverse programmed? On the ESC? I have the 9920 in reverse, maybe that's what gave me the throttle problems.
01.05.2007, 12:54 PM
The Li Saver in the RCM is a car version and you should not have any issues with it.
