Stampede Chassis Conversion Questions
TexasSP
Something, anything, nothing
TexasSP's Avatar
Stampede Chassis Conversion Questions - 10.23.2006, 10:55 AM
One frustrating thing is that the kit says it comes with everything.
Everything that is except the rod ends. My question is which ones do I need to use? The maxx ones have an inner diameter that is too large so I was thinking These would be the correct match.
Also, with the arm part of the kit there are to pieces of aluminum about 3/4 to 1" long and 1/8" wide with a hole at each end that I can't quite figure out what to do with. Any help is appreciated, maybe I am just blind to the obvious but it has me confused.
skellyo
skellyo's Avatar
10.23.2006, 11:33 AM
The Traxxas rod ends you linked should work fine.
If these are the parts you're talking about http://onelouds10.com/flm_what.jpg they attach to the bottom of the rear a-arms.
TexasSP
TexasSP's Avatar
10.23.2006, 12:23 PM
Those are the ones, thank you kindly for your help.
skellyo
skellyo's Avatar
10.23.2006, 02:11 PM
No problem. Have fun with the conversion.
crazyjr
crazyjr's Avatar
01.12.2007, 08:44 PM
I know this is an old thread, but i need to tell everybody that they need to drill the stock traxxas link ends with a .120" or 3 mm bit or you will have split the link endsIf you can even get them started
